Question about LG (CRD-8322B) Internal 32x CD-ROM Drive
My cd drive door will not open - LG (CRD-8322B) Internal 32x CD-ROM Drive
  • 2,113 Answers
Look for a pin hole in the front and put a needle or paperclip in it
Posted on Nov 27, 2013
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
WE CAN'T OPEN THE CD DRIVE ON OUR COMPUTER
I do not know the particulars of the eMac, but most CD drives have a little hole in which to insert a needle, in order to open the door manually, and extract the stuck CD. Look for it in the area surrounding the retracting door. Some units dont have doors, and inserting a pin will also force the disk right out.
Jun 14, 2010 | Computers & Internet
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
CD "door" will not open.
Push a paper clip inside the hole in front off the drive to open it manually
Apr 05, 2010 | IBM NetVista PC Desktop
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Cd rom drive door
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Feb 20, 2009 | HP GX613AA Pavilion A6300F Desktop PC
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
Door not opening
Change the drive, the drive is known to have problems and you should be fine
May 24, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
LG (CRD-8322B) Internal 32x CD-ROM Drive Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
