Question about Garmin nuvi 1450 GPS Receiver
Power loss GPS loses power when it's connected.
  • Garmin Master
  • 2,130 Answers
This is a common problem with the 14xx series. The problem is caused by a loose USB connection to the board inside. To learn more about this issue, please see the following link:
http://www.sharc.net/gps_charger_repair.htm
Posted on Nov 28, 2013
Could integration relay cause a power loss to dash and power windows and ac fan
No 1 relay can't be responsibale for power loss in more then one circuit.
Its a bigger problem .But by bigger I mean its battery voltage a main feed .
Check your battery and all the connections amd the main junction box for lose and corrioded connections this could be something vary simple LOOK
May 28, 2015 | AC Cars & Trucks
It randomly loses power while Im riding. Sometimes the power comes back automatically and other times it does not. Could it simply be the battery? Or one of the connections? Sometimes the problem starts...
I had a similar issue with a Garmin V mounted to the handlebar of my ATV using a RAM mount. I wonder which GPS you're using and how you're using it?
After determining that it only happened on the shock-prone ATV while riding trails, suspicion turned to the internal batteries. You didn't note your GPS model or application so I don't know specifics for your problem - but I wouldn't feel uncomfortable suggesting that it is an intermittent power connection. If the power source is an internal battery, batteries or battery pack; check the batter compartment for dirt, debris, etc. Clean completely. Next, inspect the terminals. These must be clean and corrosion free. They are often pressure sensitive connections - meaning they rely on squeezing the batteries together and press in the battery's top and bottom to get the + and - voltages to the GPS.
If the springs or clips that provide this pressure have become weakened - it is very possible that physical shock to the GPS could cause a momentary loss of power. This would result in a brief loss of display followed by a 30 sec to a minute or so for the GPS to boot and get a "fix" again.
Adjust or bend the clips or springs as needed to create greater pressure on the batteries. Some battery compartments reply on a hinged door to complete the battery circuit. make sure that when the door closes the springs are pressing down on the batteries instead of being bent off to the side with significantly less pressure.
If you can't get these suggestion to solve the problem - you could try to use an external power source to power the GPS. This would remove the entire battery, compartment, springs, etc from the "loose connection" part of the equation. This only works if the GPS offers an external power connection - like my Garmin V (and many others) GPS does. Unfortunately, most of the strictly hand held or trail GPS devices do not offer an external power jack for this purpose.
If you have other questions or need additional help, be sure to tell me which GPS you've got, what your application is when it fails and how you're securing it.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GPS
My devices keep losing connection with the router due to loss of power in the router.
Connect the router to a UPS to prevent temporary loss of power issues. Any electronics store will carry a UPS that won't cost you a lot.
Apr 20, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Loss of gps signal
try updating with the latest GPSfix updates via the tomtom home software
Jul 28, 2009 | Tomtom GO 910 GPS Receiver
Hi There, Just bought a new Nuvi 255, I was just driving to a destination and out of sudden, my GPS got a message mentioning, loss connection to sattelite. It stayed on for like 30 mins, till I reach my...
Unless you are driving in a dangerously remote area of some desert, or a large city, GPS units rarely lose signal. Chances are you have a defective unit, I'd contact Garmin support: Here.
Hope this has been of some help.
Jul 07, 2009 | Garmin nuvi 255W GPS Receiver
Why wont my driver side power lock work? It wont lock or unlock sometimes. How can i fix it?
It sounds like you have a lose/bad connection. If you can remove your door panel and visually inspect your connections for lose or rusted connections other wise you will have to test each connection to find out where your power loss is at.
Jun 27, 2009 | 2005 Toyota Avalon
Crackling noise then no audio at all while on motorcycle
In my opinion I suspect either a bad internal connection to the built in speaker or a faulty Bluetooth connection. Does the problem occur on both the helmet and speaker? If so, then the unit has likley had a circuit malfunction. If the helmet works fine but not the speaker, then I'd guess a broken or damaged speaker and/or speaker wire. Crackling noise is typical for broken wires or lose connections. Any decent TV repair place would be able to sort through it about 10 mintues before you have to return to for factory repair.
Sean
May 24, 2009 | Garmin zumo 550 GPS Receiver
Unit keeps losing power. Cord has power light and
I had the same problem. It was the pin inside the **** clamp that was broken. As I wiggled the plug in the unit the pin would dislodge. eventually the pin got lodged in the 12v power cord.
May 16, 2009 | Magellan RoadMate 700 GPS Receiver
I am losing satelite connection frequently. Sometime for a few seconds and sometime for up to ten minutes
Hello jacke328,
In order to maintain satellite connection your GPS receiver needs a clear view of the sky. If you are operating the GPS in areas where the view of the sky is limited due to tall buildings, hills and mountains, or dense forest, your GPS is liable to lose signal from one or more satellites and this can impact the receiver's ability to determine your current location.
If you are operating the GPS inside your vehicle an external antenna may help significantly. The body of the vehicle can act as a shield, blocking the GPS's ability to receive satellite signals. This is why most manufacturers recommend installing GPS receivers on the dashboard with a clear view of the windshield as this maximizes the amount of visible sky. Installing an external antenna on the vehicle and connecting this to the GPS can help significantly, however.
Depending on the geography of where you are operating the GPS, you may have to live with an occasional loss of connectivity. With proper mounting you can minimize this, however.
Best Regards
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Doesnt stay powered-up
Small IC chip on the back of your I/O board is losing connection. Look at my posts to other users with the same type problem. -Daniel
Mar 31, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin nuvi 1450 GPS Receiver Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
