Question about Dryers
I have a Whirlpool Cabrio model #WED6200SW1. The control panel turns on and when I hit start the heating element heats but it will not start. There is a slight humming noise but I can't tell if it's coming from the motor or the heating element. We opened it up and vacuumed out all of the lint away from the motor and took off the belt and got the same results. Could this be a door or thermal fuse? Or since it is still heating is it most likely the motor?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
The humming noise indicates the motor is either trying to run, but not doing so because of a bad motor or capacitor, or the motor IS running but cannot spin the drum because the drive belt is off/broken. If you can spin the drum easily by hand, the belt is probably the problem.
Posted on Nov 27, 2013
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Posted on Mar 12, 2009
  • 16 Answers
SOURCE: Dryer not heating
BE VERY CAREFUL WHEN WORKING ON ANYTHING WITH AC POWER CONNECTED !!
There is at least one thermal cut off switch.
It is a two terminal device usually mounted near the heating element or in/near where the hot air exhaust leaves the dryer.
It should be closed (shorted) all of the time. It should ONLY open when dryer overheats. Check it with an ohm meter with AC power disconnected. It should be a short. If open replace it.
You can also check it with power connected but you must be VERY VERY CAREFUL !!
Connect an AC voltmeter set to read 250 VAC across the switch.
Run the the dryer.
It should measure zero VAC.
If the switch opens it will measure about 220 VAC.
If it opens when it has not overheated, replace the switch.
Posted on May 11, 2009
richroth
  • 9472 Answers
SOURCE: Whirlpool LER4634EQ2 electric dryer,makes humming noise when door closes, heating element gets really hot, but start button doesn't move drum, heating element shuts itself off
See if you can spin the drum with little resistance or is it really hard to spin?
Posted on Oct 31, 2012
richroth
  • 9472 Answers
SOURCE: Model WED6200SW1 Whirlpool dryer will not start. Push power, lights come on and element heats up but drum doesn't turn.
The motor is dead and will need to be replaced. Here is the motor to order.
Posted on Nov 14, 2012
Whirlpool cabrio dryer not heating. Already checked the fuse box and hoses. Can't open back;fused. No videos online show our model. Can't figure it out! It's less than 2 years old. Model: WED5610XW1
Start from about 0:50 seconds and watch how to remove the lower panel. Yours will be the same. http://www.searspartsdirect.com/model-number/wed5610xw1/1198/0151200.html
This has the parts breakdown to help you out from there. You most likely have a bad heating element.
This one will show you how to test several different components for heating issues. Yours will be mostly the same. Start at 0:50 and this will help you diagnose the heating element and limit switches.
Jan 15, 2017 | Whirlpool Dryers
Cabrio electric dryer WED6200SW1 runs but will not heat up. What do i need to do? And how?
hay Aric , it sounds like you have bad element or fuse . test as follows unplug wires to the element and turn unit on if you get 120v to the element replace it if no power then it got to be a fuse or the door switch test them for continuity , good luck APPLIANCES R EN
Feb 24, 2013 | Whirlpool WED6200S Electric Dryer
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Apr 08, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Jul 24, 2009 | Whirlpool Dryers
Whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
Feb 03, 2008 | Dryers
Dryers Logo
152 people viewed this question
Top Dryers Experts
