Question about KitchenAid Food Mixers
Mixer throws food out of the bowl
The mixer seems to go the same speed no matter what setting it is on. That is less of a problem for me than the fact that it throws all the batter out of the bowl, even with the splatter guard on it. It's an old hand me down mixer, so there is no warranty or anything.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
How do the buttons feel when you push them down? If they feel sticky or hard to push at all, the lever inside that cancels other switches when you push a new one down may be seized up with old, hardened grease. In other words, one switch may be stuck down, even though it doesn't appear so. Not sure how much of a do-it-yourselfer you are, but you could remove the bottom plate and just push each button. If it doesn't look like each switch is not engaging as they should, you could spray the area with contact cleaner/lubricant from Radio Shack just to see if it helps. Considering the price of new mixers, unless it has sentimental value, it is probably not worth spending much time on.
Posted on Nov 27, 2013
SOURCE: KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
Posted on Aug 19, 2007
SOURCE: kitchen aid tilthead mixer will not lock down
The solution for both of these is a large screw that sits at the base of the head where the head and the base meet - you'll see it when you tilt the head up. This screw should not be all the way in. You can adjust how low the head goes- in the case of your blades hitting the bowl you'll want to let the screw out a bit; in the case of the locking, you'll want to screw it in a bit more.
Posted on Mar 17, 2008
  • 9 Answers
SOURCE: mixer speed settings
It could be the phase control, or it could be that the governor assembly or associated spring is missing or malfunctioning.
Posted on Mar 25, 2008
Loringh
  • 185 Answers
SOURCE: Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
How do I fix my Kitchen Aid Professional 5 mixer that will not change speeds?
The speed adjustment is defective. You will likely need a service centre if you cannot open it up and find the problem and change any defective parts etc.
Nov 24, 2014 | KitchenAid KP50PS Professional 5 Series...
BEM800 speed going flat out
It is likely that the speed control switch is defective.
Nov 30, 2013 | Breville Food Mixer BEM800
Kitchenaid mixer speed
If it has suddenly got high speed all the time and the two adjustment screws at the top of the speed control board are not loose and have not been messed about with the most likely solution will be to replace the phase board. That's the little PCB just above the speed control board with the 6 wires coming out of it.
Nov 23, 2013 | Food Mixers
I need a replacement bowl
Goto http://www.dealtime.com/rival-mixer-replacement-parts/products
Dec 07, 2012 | Rival Stand Mixer 12 Speed Model...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Food Mixers Logo
43 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
