Question about Dynex DX-LCD32-09 LCD TV
My dynex tv only shows channel not available message?
I removed the 3 red white and yellow audio/video cables from my xbox 360 and when i put in the cable that showz tv channels it only shows channel not available message ive switched cables ove rand over but it stays the same. now i cant even play my xbox 360 or wii. i use a directv cable/sattilight box.
  • bien
    bien Nov 27, 2013
    I pressed the imput button then scrolled to A/V and its
    showing tv again. Thanks for the help!
  • 794 Answers
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Posted on Nov 27, 2013
3 Suggested Answers
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
dandre10
  • 63 Answers
SOURCE: How do you connect a Nintendo 64 game station with
connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
Posted on Jan 05, 2010
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
My son has turned on his x box which seems to show the normal green light but cannot see anything on any of the tv's in the house. This worked yesterday but I put it in the cuboard last night and now it...
check the video cable that hooks to the xbox... it has a switch for normal tv and hd tv.....and also try a different input on the tv... but first check to make the cable is hooked to the tv correctly...red 2 red, yellow 2 yellow , and white 2 white.....if all of that ok then xbox quite...
Feb 04, 2011 | Microsoft Xbox 360 Console
I need specific instruction on how to connect Dynex docking station and ipod to s video and tv component settings
You will need the red/yellow/white video cables and just hook up the yelow and white up to the xbox and the other end yellow and white to the tv than turn the tv to channel 3 and this should work.
May 19, 2010 | Televison & Video
I have no picture but hear the sound of the system on my tv
It could be 3 things:
Your tv connections are disconnected and need to be replaced. See if anything else works when plugged into these connections.
Your cable cord could have a disconnect internally and the cord needs replaced.
Your graphics card on you XBOX 360 is shot any you need to replace it.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
How do i connect my xbox 360 to a big screen tv like the box ones,with a rf modulator?
Hello there:
best regards mike
Jul 30, 2009 | Dynex RF Modulator AV Signal Converter
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Dynex DX-LCD32-09 LCD TV Logo
87 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
