Question about Century Buick AC A/C Heater Blower Motor 1997 Century
How to video on replacing blower motor 97 buick century
Blower motor resistor located on 2004 buick century
Does your Buick have manual or automatic cilmate control ? Could have a blower motor control module or processor ! It , if it had a resistor it would be near the blower motor . It's located under the dash below the glove box . To get at it you need to remove the panel under the dash . Video on youtube showing how to test blower motor electrical circuit .
Dec 28, 2016 | Buick Cars & Trucks
Replace blower motor 97 buick century 3.1
under the dash passenger side , you have to get upside down, be sure the squirrel cage is the same depth on the new piece as one to deep will bind up and could burn up the motor befor you figure out why it is not turning
Nov 27, 2013 | Buick Century Cars & Trucks
Replace blower motor 97 century limited
this is under the glove box area-you'll need to take it out to get to it and you probably need to got upside down to get at it-also there is a part called blower motor resistor that is down there that I would also replace- cheers Denny
Nov 27, 2013 | 1997 Buick Century
1998 buick century when air or heat is on I hear a squilling noise , what is it?
Replace the heater blower motor or the caged fan attached to the blower motor, or both.
Oct 28, 2013 | 1998 Buick Century
1998 Buick Century w/ manual control, smelled burning odor and blower motor quit working. Control Module?
blower resistor is common to burn causeing smell. check with dealer, there may be a campain on this problem. if not. replace resistor and harness (pig tail) and blower motor..
Jan 21, 2013 | 1998 Buick Century
Will blower/fan motor from 1995 century fit into a 1997 parkavenue
the chances of this is slim I checked the Part numbers of the 2 motors and they are different possibly the plastic fans attach differently, and can cause problems with the depth or width the mounting holes may not even match up ...sorry I dont have better news..97 park ave motor GM part # 88960339 and AC delco # 15-8959 And the 95 century numbers are GM #52498870 AC delco # 15-8535 Hope these help...
Dec 07, 2009 | 1997 Buick Park Avenue
Blower motor stays running
by now u figured out that you pull the 30amp fuse from the panel on passanger door size of dash
the lower blower motor operates on another 15amp fuse
Jun 26, 2009 | 2000 Buick Century
Century Buick AC A/C Heater Blower Motor 1997 Century Logo
461 people viewed this question
Top Century Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Century Heating and Cooling Expert? Answer questions, earn points and help others
