Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Warming plate trips GFI.
After coffee is done as soon as the warming plate clicks on it trips the GFI plug and shut down the plug, hence cold coffee when I get up !!
I love my Krups 867 it has served me well since 1996 not 1 problem until now. Can I fix it or can it be repaired ??
Thanks, Richard
  • 2 more comments
  • Richard Barone May 09, 2009
    No the plug is not a grounded plug,it is only a 2 prong but it's pluged into a gfi outlet.
    I can take it apart so I will look inside to see if there is a leak and I will let you know if this works.
    Thanks, Richard
  • Richard Barone May 10, 2009
    I took the bottom off and nothing was wet all looked good.. I cleaned and wiped the inside down all looked good but when I plugged it in and brewed some water all was fine until the warming plate clicked on about 5 minutes later, then the clock flashed once and the it click off ???
  • Richard Barone May 11, 2009
    I'm a pretty handy guy,there's not a lot to this thing. When I took the bottom off I did'nt see any black spots or burnt marks I just don't know what to check? If you have a suggestion please share, if I don't think I can do it then I'll take it in somewhere. If nothing else I can disconect the warming plate.
    Thanks, Richard
  • Samuel Charles Spriggs May 11, 2010
    There is a short to ground in the warming plate circuit. Most likely just wet. If you can take it apart, dry it out (rag, hairdryer) and check for internal leaks which may be getting that area wet. It may just have been a one-time spill which caused it.
    The question is how is the coffee maker grounding.
    Does the power cord have a gounding plug (3-prong) on it?
    President:
  • 1,489 Answers
Well, it's still a short to ground. But sounds like it's not simple. Needs to go to the shop, unless you want to try your hand at it.
Charlie
Posted on May 10, 2009
  • Samuel Charles Spriggs May 11, 2009
    You most likely wouldn't have any burn marks -- a GFI is so sensitive and quick, it doesn't allow time for anything to get hot enough to scorch.
    I'm just brainstorming here.
    Maybe there's corrosion on a circuit board which you could clean.
    Or maybe the thermostat and/or relay which controls the warming plate has burned contacts which causes enough arcing to trip the GFI -- these contacts are probably not visible, they'd be inside the devices.
    If you can access the contacts, sandpaper/emery board and electrical contact cleaner might do the job.
    all for now...
Water wont heat. Warmer has no heat but light is on
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Jul 03, 2010 | GE 106591 Coffee Maker
Brew shuts off before brewing has ended or warming
Hello CJ, it sounds as if you've got a faulty control board. I would contact Cuisinart and see if they can assist you with either a repair or a replacement unit.
Cuisinart is pretty well known for their customer service and I would expect they will handle yor request promptly and most likely will get you a replacement at little to no charge.
You can call them at 1-800-726-0190 from 7 AM to 11 PM Monday-Friday and from 9 AM to 5 PM Sat & Sun.
Here's the link to their web site, for any other questions you might have
http://www.cuisinart.com/support/us.html
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Cuisinart DCC-1200 Coffee Maker
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
Cold coffee
Is it the coffee maker itself or the warming plate?
If it's the warming plate I would suggest geting a coffee thermos similar to the ones they have at IHOP and other breakfast places, it will keep your coffee hot all day if you first heat it up with very hot water and your coffee will not have the burned taste
Please answer if the answer works for you, thanks
Feb 13, 2009 | Cook's Essentials CEMB10TC
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
135 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
