Question about D-Link DIR-625 (790069292637) Wireless Router
Cant find d link router
I bought a d link wireless router for my apartment at school... the two laptops work fine and pick it up but my pc cant even find the router.. any idea what i could do
  • punlin50 Oct 11, 2007
    yeah its a desktop and i do have a wireless card in it but it still cant find the router
  • Anonymous Feb 03, 2008
    I have a wireless card, set to detect B/G/N. It doesn't see the d link router. It see's neighbors routers, and laptops see the home d-link router.
    President:
  • 317 Answers
Is your PC a desktop?  Are you connecting it directly or trying to connect wirelessly?  Most desktops don't have a wireless card installed, you'll have to get one of those.  Look at the back of the tower and you'll see a 6inch long antenna sticking out of one of the expansion slots.  If not, then you don't have one.
Posted on Oct 10, 2007
SOURCE:
Why won't laptop connect to wireless internet? Wifi is working, another computer in home is fine
are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
Feb 12, 2018 | Compaq Presario CQ62-215DX Laptop
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
CANT GET MY LAPTOP TO CONNECT TO INTERNET
Are you able to change the SSID, create a new key, save then reboot the router? Then let the laptop find the new network. If this does not work, it may be time for a new router
Jul 09, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Laptop won't detect wireless connection (but does detect others)
you look to be having the software but you need to confirm if its the wright software. make sure that you getting them from the software CD that come with the laptop. if your downloading from the internet make sure that its from the wright manufacture of the your laptop. if your not sure please send me the wright model and brand of your computer i will help you to link you to the site.otherwise your wireless card should work.
Jun 01, 2009 | Computers & Internet
PC works fine with Linksys USB card, but laptop's NetGear won't.
It looks like you are either using TKIP or AES just put the wireless to use MIXED and it will solve your problem.
Mar 19, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection issues (to be origional lol)
Is your desktop pc still working fine.., clear your preferred wireless networks in your laptop, try searching for the wireless network again, check if you are abe to pick up any other wireless network in your laptop, so that you can conclude whether the problem is with the laptop or the router..if not try reconfiguring your wireless settings in your wireless router and check it out ,that will fix your problem..all the best..
Aug 17, 2008 | Computers & Internet
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link DIR-625 (790069292637) Wireless Router Logo
723 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
