Question about LG DLE5932W Electric Dryer
Lg tromm DLE5977 won't start the tumble
If you hand start the tumble and are fast enough to shut the door and press start, it will keep running
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Posted on Nov 27, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
KevinWhite
  • 1902 Answers
SOURCE: My LG TROMM Dryer won't start the tumble when set.
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, also check the belt if that is fine. Please get back to me if you have any other questions.
Kevin
Posted on Jul 06, 2011
heatman101
  • 43501 Answers
SOURCE: my LG Tromm DLE 5977W
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Aug 05, 2011
I have a LG Tromm it starts running in wash mode then a few mins. into cycle it shuts off no codes there is nothing on display
Here's a reset that could work:
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE. Good luck
Mar 07, 2018 | LG Washing Machines
Not tumbling
check the pully on the motor and check the tention of the drive mechanism. It's usually a belt around the drum.
Jan 24, 2014 | LG DLE5977 Electric Dryer
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
My LG Tromm DLE 5977W will tumble but won't heat
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
LG Tromm dryer says clean filter and won't run. Filter is clean.
CHECK YOUR HOUSE VENTING. MANNY TIMES IF THE EXAUST AIR IS NOT GOING OUTSIDE FAST ENOUGH IT WILL GIVE YOU THE SAME ERROR.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 15, 2010 | LG Dryers
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Dryer not tumbling
Broken drive belt, or drive belt disengaged. Or stretched. Or lost tension spring. Humming is motor running, not driving drum.
Jan 21, 2008 | LG DLE5977 Electric Dryer
LG DLE5932W Electric Dryer Logo
123 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
