Question about Samsung DV337 Electric Dryer
Door is ajar message when shut light comes on but doesnt run
Doesn't run getting door ajar message and light is on in dryer
  • Samsung Master
  • 2,963 Answers
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Posted on Mar 01, 2015
    Scholar:
    New Friend:
  • 81 Answers
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Posted on Nov 27, 2013
Ford ZX2 courtesy lights and chimes
Sounds like a problem with the sensor in the driver's door latch.
Jun 28, 2013 | 2002 Ford ZX2
03 gmc 2500hd 6.0 gas. truck is going crazy
Check door switch connection and operation.
If the door switch is part of the door lock mechanism, within the door itself, then remove door panel, disconnect the mechanism's electrical connector and re-check that the interior light no longer comes on with that door ajar. If it doesn't, then you likely have a faulty door lock mechanism, which you will have to replace.
This faulty switch will also have the affect on your random central locking function.
This is not likely connected to the engine performance issue.
Nov 03, 2012 | GMC Cars & Trucks
1999 mercury villager interior light won't go off.
If the door adjar light is on than you have a bad door switch. They are part of the door latch assembly. It is more common for the drivers side to go bad but it could be anny of them. A scan tool would be helpful in narrowing down which one it is. What you can try is spraying carb or brake cleaner into the part of the door that holds the door shut (the latch). Spray it into every nook and crany in that area. Open and close the door several times will a serving the door adjar light. If it goes out problem solved. If it doesn't go out get it scanned to see which one has failed and then pull that door pannel to inspect. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 19, 2012 | 1999 Mercury Villager
I have a 2010 hummer H3. the doors message is on the dash and the interior lights wo't shut off. of course we checked all of the doors. is there a quick fix? the service dept is closed all weekend
you have a bad door ajar sensor dont know which one it is until you replace one if it doesnt go off then replace old one and go to next one
Sep 18, 2010 | 2006 Hummer H3
2003 Jetta Door ajar light keeps coming on and
You need to replace the door jamb switch. Little button on the door jamb that is pressed in when doors are shut.
May 03, 2010 | 2003 Volkswagen Jetta TDI
Door Ajar message comes up even when all of the stores are shut. Interior Lights and Lights on side view mirrors stay on. Lights can be shut off but the Door Ajdar message remains on.
I have this same problem. A mechanic friend told me that basically the grease they use to grease the door latches cause a sensor to think the door is open. He said to buy something thtat will break up this stuck grease, but also has lubricating effects. I forgot what he told me to buy though.
Aug 07, 2009 | 2003 Mercury Mountaineer
Message center says driver door ajar but shut tight
this problem is caused by a small switch inside the door that is attached to the door latch mechanism, it is called a door ajar/coutresy light switch, there are one of these for each door, the dealer can run a test that will id the bad switch very quickly, the output from these switches goes through a control called a lighting control module (LCM), it has the ability to test itself.
May 29, 2009 | 2002 Lincoln Continental
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Samsung DV337 Electric Dryer Logo
117 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
