Question about Atari Flashback 2 Console
No color picture and sound but no color
We moved our tv upstairs, we have a nice picture and sound but no color!
check for a loose connectors and fixed it to the pin terminal .
Oct 27, 2012 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
Have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
NO COLOR
I RESET TO THE DEFAULT SETTINGS AND THE COLOR RETURNED
WAYNE
Jul 23, 2008 | Sanyo DVW-7100A DVD Player/VCR
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Atari Flashback 2 Console Logo
42 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
param99
Level 1 Expert
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
