Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Ice machine water won't keep running
I have a SUPER old Ice-o-matic by welbilt. I plugged it in for our season(it's been off all winter) and it gets cold and the water starts to flow, but after about 2 mins the water stops. Fan's still running. I've tried adjusting presure control, nothing. Any advice?
SOURCE: Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
Posted on May 30, 2009
bozcro
  • 867 Answers
SOURCE: i have a ice o matic that is old but still runs
yes, relay or motor.
Posted on Sep 09, 2009
projdoc
  • 2237 Answers
SOURCE: I HAVE A ICE O MATIC 0250HA4 which start making
the thickness sensor is too close to the where the ice is being made. you will need to either bend it out a bit or use the adjustment screw. the latter is more preferred.
Posted on Jan 12, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have an under-counter ice-o-matic model #IFQ-1
Have you cleaned the unit lately. There is an ice thickness probe that can be adjusted to compensate.
Posted on Jan 17, 2010
  • 112 Answers
SOURCE: I have an ice machine (Ice O Matic) Mod #
You have to remove the bin to access the inner workings and the hi-temp safety is strapped to the suction line. You just look for two black wires disappearing into the line insulation to find it.
To remove the bin you: 1. Unplug the unit. 2. Take the top off and remove the sliding bin door, 3. Remove the front bottom louver, 4. Look straight back and disconnect the drain hose from the bottom of the bin, 5. In the louver opening look in the top corner and there will be a screw in each side going straight up into the bottom of the bin. Remove these two screws and lift the bin up and out.
If you are going to run the unit with the bin off you will have to cover the condenser area so that the air is forced over the condenser and be prepared to catch any ice that is produced.
Posted on Jan 04, 2011
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Not working
Is the condenser fan running if so is the compressor running? check both of them to make sure there not grounded out. also check the condenser fan motor to make sure the armature is not rusted in place.
Jun 12, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
No water going into o matic ice maker
check the water float that is how the unit deterines when the reservoir has enough water it could be stuck
Nov 04, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
Not making enough ice
What is the ambient air temperature in the location it is installed??
Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
Water keep running no ice only making 12 to 15 cubes of ice,
dirty condensor coil, condensor fan motor not working, low on freon,taking in new water during the freeze cycle due to float or unlevel machine.
Sep 24, 2011 | Ice-O-Matic ICEU220HA Undercounter Ice...
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have an old iceu150ha sku # wb3765001 that is not freezing and or making ice cubes, the compressor is good, the pump is good and the fan works great. the water just keeps comming down like a waterfall...
If the evaporator is not getting cold, it could be lack of charge or the coil is dirty and not allowing the compressor to properly cool. Try cleaning the coil first.
Nov 09, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
169 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
ray gallant
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
