Having problems with my dj turntables....It doesn't seem to play when it is on the speed of 33.....
  • 153 Answers
Are you using 33 records?
check out my eBay Store
Posted on Nov 27, 2013
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
Is this a belt drive turntable? If so, replace the belt - its slipping.
Dec 30, 2013 | Pyle Pro - PTCDS1U - Home Ptcds1u...
Motor stutter
yes you reLly are a dj, only doesn't know how you have to maintain simple gear , pioneer amp a assume?
You don't need new tt, just knowledge and being a 'dj' , search and finf on google
Nov 28, 2013 | Stanton Audio Players & Recorders
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
Turntable speed stuck at 45
You should visit the website of the makers or phone them for advice as it's new. It may need to be replaced.
Dec 28, 2012 | Audio Players & Recorders
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 02, 2009 | Technics SL-1200MK2 Turntable
Speed increased +3rpm every half second
You have drive issues. There is no easy way to fix or to isolate the problem. You'll have to take it to a service technician who can test your unit, and fix the problem. Usually it's one of the 3 main IC (integrated circuits) which cause this problem.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Oct 14, 2008 | Technics SL-1210 Turntable
Cd malfunction
Lens cleaners aren't enough. You might have to take it to a service center to have it opened up and professionally cleaned.
If there is no damage to the cd traverse assembly, then the issue might be with either the quality of your burned CDs, or method used to burn.
I always tell people to burn at slow speeds - 4x is ideal. Yes, I know it's slow, but it will burn your cds at a better quality.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Jul 01, 2008 | Pioneer CDJ-800MK2 Turntable
18 people viewed this question
 Grubhead
Grubhead
