Question about Comfort Zone Heating & Cooling
I purchased the Ceramic Fireplace Heater, Model #CZFP1 over the summer from a Good Sams Vendor that was set up at one of the NASCAR races this summer. I used it twice on a low setting, only running it for about two hours at a time. The third time I turned it on, it ran good but then cut off. Now the only thing that turns on is the LED flame. Is there a reset button somewhere or what can I do to fix it. We spent $50 on this item and the sales person talked very highly about this product.
Hhh
Posted on Nov 27, 2013
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
  • 8 Answers
SOURCE: vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Posted on Dec 12, 2008
johnsonr1
  • 91 Answers
SOURCE: Cost per hour to run Model # 5840 heater
take the wattage of the heater, divide it by 1000 then multiply that by your cost per KW/hr from your electric bill, then multiply that by the number of hours you operate the heater. That will give you the exact cost to operate at full heating per hour.
Posted on Nov 04, 2009
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Lineup for Sunday's nascar race
Sunday 19 Octobers 2014
Noon, NASCAR RaceDay, FOX Sports 1
1 p.m., NASCAR Sprint Cup Series Countdown, ESPN
2 p.m., NASCAR Sprint Cup Series Race at Talladega, ESPN
2 p.m., NASCAR Sprint Cup Series Race at Talladega (simulcast), ESPN Deportes
12:30 a.m. (Mon.), NASCAR Victory Lane, FOX Sports 1
1 a.m., NASCAR Sprint Cup Series Race at Talladega (re-air), ESPN2
Oct 18, 2014 | Video Game Consoles & Games
What is the satus of my cancel order investigation?
You'll need to take that up with the Vendor. FixYa is a question-and-answer site we can't act as your agent.
Aug 11, 2014 | Computers & Internet
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Lost Nascar Racing 2003 CD, have key code
u probbly have to buy another game or just torret the file
Mar 15, 2010 | Papyrus Nascar Racing 2003 Season for...
Unable to set up scanner at NASCAR event
chances are that you have locked out the freq u are trying to use ... do you know how to operate the unit? if not i can give you some pointers
Apr 14, 2009 | Uniden BC92XLT Handheld Scanner
Computer game with no instructions or manual
hi ........
yes u can get them from
http://www.answers.com/topic/nascar-racing-2003-season
u can also check the manual in the installation disk
please comment!!! and give ur rating
Dec 28, 2008 | Sierra Online, Inc. NASCAR Racing: 2002...
Logitech nascar racing wheel ps2
Make sure the driver is correctly installed for the hardware. Also if for a game in the options menu should be something along the lines of controller or input, just change the input to the pedals
Nov 06, 2008 | Logitech NASCAR Racing (963339) Wheel And...
Samsung LCD HDTV - Color Problems
voltage adjustment for y-sus board or power supply
Mar 17, 2008 | Televison & Video
Heating & Cooling Logo
60 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
