Question about Brother PE770 Computerized Sewing Machine
Messages about safe device activated & press the needle position button
In the middle of embroidering the machine stopped & "the safety device has been activated." message came on & then "press the needle position button to raise the needle." message. Nothing happened. Just a noise and then the same message. Sounds like something is stuck and won't lift.
    New Friend:
  • 20 Answers
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Posted on Dec 12, 2013
4 Suggested Answers
  • 1116 Answers
SOURCE: There's a grinding sound whenever I press the
Sounds like the shuttle needs to be cleaned.
Turn off the power and open the needle plate.
Remove the bobbin and bobbin case.
Clean the area from lint and any thread that may be trapped.
Posted on Mar 01, 2010
SOURCE: Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Posted on Nov 03, 2010
SOURCE: brother Innovis2500d embroidery unit attached and error message comes up that the needle position button is down. The button is stuck.
it sounds like the machine needs to be serviced
Posted on May 04, 2012
Error message "the safety device has been activated. Is the thread tangled? Is the needle bent?" Occurred after needle no 5 broke and fell out. The machine
If the safety has been activated, there is something wrong with the machine that could potentially be dangerous--to the machine or you. You should probably take it to a technician.
Mar 15, 2017 | Sewing Machines
My Elisimo keeps stopping in the middle of an embroidery, red light on, presses foot lifter locked, sits for a minute or so and then green light comes on and i can continue embroidering. Is it board?
may be the safety device activating if it hasn't been oiled in a while. Make sure the area around the machine and embroidery arm is free of anything that could hit it and cause it to stop or strain.
Nov 30, 2016 | Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
At start up machine says press needle position button. All that happens is the motor revs up then says safety feature has been activated. Any ideas?
I used this machine in my middle school classroom. That message was in the first start up of the machine, I think it just resets the machine. The larger model also has a beginning reset button that just adjusts the arm of the machine. Is the machine working fine after the reset? Hopefully "sew"
Jan 13, 2015 | Brother PE-770 Embroidery Machine
Safety Device Activates but no error message
It sounds like there may be something inside the machine. This happened to me twice. The first time was the wrong stabilizer. The second time I had a piece of thread inside the machine. When I opened it to see the thread was activating the error beep in the machine. I hope it helps.
Mar 10, 2014 | Singer CE-200 Quantum Futura Computerized...
There's a grinding sound whenever I press the needle position button & the error message "The safety Device have been activated" pops up on the screen
Mar 01, 2010 | Brother SE-270D Computerized Sewing...
Dec 22, 2009 | Brother Sewing Machines
I was embroidering with my machine and then the needle starting stitching in slow motion and then stop and I got an error saying the safety device had been activated. I closed that window and now it is...
Unfortunately you are completely dictated to by the computerized machine, you can only try and do what it says, if you have problems with any computerized machine the only solution is to get it to a Brother dealer or find their website for advice.
Nov 01, 2009 | Brother Sewing Machines
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Brother PE770 Computerized Sewing Machine Logo
182 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
