Question about Electrolux Washing Machines
Push button switch does not work
Aquashower 800
    Genius:
  • 1,198 Answers
Sounds like a really dead machine. You have to start at the outlet, with something to see if it's working.
If the outlet is good, are any lights or indication of power on the machine working?
If no indication of power shows, a technician needs to open the machine to see what's wrong.
Posted on Nov 27, 2013
2 Suggested Answers
  • 174 Answers
SOURCE: Our Electrolux washing machine of
if the noise your describing is a grinding rumbling sound when you turn the drum it is likely the main drum bearing have failed. you can usually detect play in the bearing by lifting the drum and seeing what movement there is compared to door seal area .1mm is the maximum 2mm would give 6mths to 12mths 6mm failure imminent.
Posted on Nov 20, 2010
1993 800 suzuki intruder starter button wont work no clicking noise starter relay is new any suggestions
Check battery, check connections corrosion causes bad connection. Double check starter button switch, it may be bad. You may be able to verify this switch by "jumper" bypass of the switch..
Nov 30, 2013 | 1993 Suzuki VS 800 Intruder
Push button start switch is not working
Hi Hiedi_jack, you probably need a new starter button switch and I am sorry you can't find the first and best tool you ever bought for your Harley but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
2004 Suzuki Motorcycle Service Repair Workshop Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 02, 2012 | 2004 Suzuki VS 800 Intruder
When the ignition switch is pushed all the bike does is clicks. It will push start and run with no other problems.
If you push the starter button and the solenoid clicks, the button is good. Take a wire and jump the two posts on the solenoid or touch the two cables together. If your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , unless the manufacturer sells replacement parts so you can repair the starter. most manufacturers only sell replacement starter brushes.
Nov 22, 2010 | 2001 Suzuki VS 800 Intruder
Our Electrolux washing machine of model Aquashower 800 , spinner not working properly. Drum seams to be shaking and gives sound of friction.
Nov 20, 2010 | Electrolux Washing Machines
Lutron Glyder Slide Dimmer GL-603P (new dimmer switch) on - off by pushing the button in center of knob -- pushing button does not turn dimmer on -- seems to be stuck in the off position -- is dimmer...
Sadly, yes, it just sounds like the switch got stuck. You should be able to yank that knob off and try to manually unlatch it with something thin and long (like a pencil) - just, do me a favor, and make sure whatever you use isn't conductive, there shouldn't be any exposed electrically, but just be safe about it.
If that doesn't work, call their tech support center at 1-800-523-9466 - they will most likely replace it for you.
Oct 04, 2010 | Lutron GL-603P Glyder 3-Way 600 Watts...
I have an AsusP5P 800 mother board and the unit won't power on.
I had a very similar issue like this, how many RAM modules do you have installed? if you have 2 DIMM installed try removing the memory on at at time(try interchanging the RAMS), see if turns on. if not might be the motherboard itself thats possibly defective.
Feb 14, 2010 | ASUS P5P800S Motherboard
Will rarely eject Cd
Either switch is about to go bad, or the plastic activator underneath the eject button, which activates the switch is worn.
You can open it up to look, but I would suggest professional repair for something like this. If the electronic switch is bad, it will need to be replaced, and un-soldered from it's board.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 16, 2009 | Pioneer CDJ-800 Turntable
Washing Machines Logo
152 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
