P-45C Gear broken - Office Equipment & Supplies
  • 189 Answers
Your inquiry did not list a brand name for the shredder but I assume it is a FELLOWS BRAND. Go to their web site for parts.
http://www.fellowes.com/us/en/support/Pages/faqs.aspx
Posted on Dec 10, 2013
P-45c shreeder motor runs but blades do not turn got all paper out but still do not turn
David,
More than likely, you have stripped the plastic gear inside. Those gears can sometimes be difficult to find and purchase. I would suggest trying to open up the top so that you can confirm if the gear is stripped. I would also suggest not putting as much paper through the shredder as they say it will handle. Hope this helps!
May 20, 2015 | Fellowes Office Equipment & Supplies
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
Burner presure of pitco 45c lpg you said free
This information is generally stamped on the data plate. I believe it is 10" WC manifold pressure. 12" WC is required for the supply pressure with all other equipment on the line on. Hope this helps. All service and install manuals are available on www.pitco.com
Jun 18, 2011 | Pitco Frialator 45C Deep Fryer
If you are asking for the standard operating gas pressure on manifold of pitco fryer, it should be 10.5 inches of water coulomb.
Regards.
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
Pitco 45C- fryer lights and burns aprox. 5 to 8 minutes, then flame and pilot go out. However it will relight without having to reset anything. This info is coming from the owner and I have not seen the...
I assume that the fryer has auto ignition feature. Try to check if the hi limit sensing bulb (located inside the fry tank) is not touching the fire tube, it must have at least 3 millimeter clearance with respect to the fire tube otherwise, high temperature will be sensed that will trip (@ 450F) its mechanical contact which will in turn shut the burner operation and will reset once it is cooled down.
The same with the manual ignition fryers.
May 10, 2011 | Pitco Frialator 45C Deep Fryer
45c+s pitco. Pilot will not light, tryed to reset overtemp. It seems a little gas comes out as it tries to light but only for a split second. After that nothing. Gas is on everything looks ok.
If the hi limit (overtemp) tripped on temperature much lower than 450F ( hi limit cut off temperature is 450F ) it needs to be replaced
Check for any dirt or clog on pilot orifice.
Check the thermopile, it should be free of soot or any form of dirt. If it is clean and could not hold pilot flame during start-up, chances are, it is bad and needs replacement. You can verify electrical output of thermopile using a volt meter set at millivolt, when properly heated, it generates 500 to 750 millivolts.
Check also your gas tank, pressure may be low.
Oct 26, 2010 | Pitco Frialator 45C Deep Fryer
Fellowes P-45C shredder
Janet,
Shredders need oil. You must oil the cutters every 500 or so pages or jams like this one will cause the blades to seize. If you haven't been oiling it at least monthly when not using it, it will also jam in the manner you describe. Care and feeding of a shredder is very important. Also, its considered a non-warranty repair if the oiling is not being done. However, call Fellowes directly to see what you can work out.
May 25, 2008 | Fellowes Powershred P-45C Shredder
Have to turn off manually
Either there is a piece of paper that is jammed where the paper in sensor is located, or there is paper fibers covering the paper in sensor, or the paper in sensor is defective.
The paper in sensor is usually located in the center of the shredder where you place your paper. Once you locate your sensor, you can try blowing it out with a can of air that is used to clean your keyboard out.
Since the opening for the paper or the Thoat width is 9", the switch should be close to 4.5" towards the center.
To try to help you located the sensor, take a piece of 8 1/2 " x 11 paper and fold it in 1/2 Long ways. This will place a crease in the middle of the paper. With the power off, or unplugged, place the paper in the shredder and look around where the middle of the paper (crease) lines up in the shredder. You might need a flashlight to help you located it. It will either look like a slot, or a little black lever.
Hopefully you will be able to blow the sensor out and clean it.
Good luck.
Jan 29, 2008 | Fellowes Powershred P-45C Shredder
44 people viewed this question
k24674
