Question about Fellowes Powershred P-45C Shredder
P-45C gera broken - Fellowes Powershred P-45C Shredder
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
P-45C Gear broken
Your inquiry did not list a brand name for the shredder but I assume it is a FELLOWS BRAND. Go to their web site for parts.
http://www.fellowes.com/us/en/support/Pages/faqs.aspx
Nov 27, 2013 | Office Equipment & Supplies
Burner presure of pitco 45c lpg you said free
This information is generally stamped on the data plate. I believe it is 10" WC manifold pressure. 12" WC is required for the supply pressure with all other equipment on the line on. Hope this helps. All service and install manuals are available on www.pitco.com
Jun 18, 2011 | Pitco Frialator 45C Deep Fryer
If you are asking for the standard operating gas pressure on manifold of pitco fryer, it should be 10.5 inches of water coulomb.
Regards.
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
6303 decode?
J?ja, ef ?? ert bundinn vi? ?kve?na net allt sem ?? ?arft a? gera er a? opna s?mann til a? nota ?a? me? ??rum GSM-s?mkerfi. ?? getur fengi? opna k??ann ? gegnum netinu. Gef?u IMEI n?meri? ?itt og f? l?s merkjam?l fyrir ur fars?ma ........ ... .. ?? f?r? einnig ? gegnum ?rugga .......... ?g vil benda ? heimas??u l?s-Zone.com sem er a? gera g??a ?j?nustu ..... ?? getur n?lgast ?essa vefs??u.
Jan 15, 2011 | Nokia 6303 Cell Phone
45c+s pitco. Pilot will not light, tryed to reset overtemp. It seems a little gas comes out as it tries to light but only for a split second. After that nothing. Gas is on everything looks ok.
If the hi limit (overtemp) tripped on temperature much lower than 450F ( hi limit cut off temperature is 450F ) it needs to be replaced
Check for any dirt or clog on pilot orifice.
Check the thermopile, it should be free of soot or any form of dirt. If it is clean and could not hold pilot flame during start-up, chances are, it is bad and needs replacement. You can verify electrical output of thermopile using a volt meter set at millivolt, when properly heated, it generates 500 to 750 millivolts.
Check also your gas tank, pressure may be low.
Oct 26, 2010 | Pitco Frialator 45C Deep Fryer
Carriage jam
hi,
Just open the printer and u will find in right hand side one black colour unit is there it moves two and fro and insite it there is a gear it is connected through other mechanism gear in left hand side after opening it u will definately find that its hinge is broken or gera is broken.
replace it ang ur problem will resolve,
bye
wasim
Jul 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Have to turn off manually
Either there is a piece of paper that is jammed where the paper in sensor is located, or there is paper fibers covering the paper in sensor, or the paper in sensor is defective.
The paper in sensor is usually located in the center of the shredder where you place your paper. Once you locate your sensor, you can try blowing it out with a can of air that is used to clean your keyboard out.
Since the opening for the paper or the Thoat width is 9", the switch should be close to 4.5" towards the center.
To try to help you located the sensor, take a piece of 8 1/2 " x 11 paper and fold it in 1/2 Long ways. This will place a crease in the middle of the paper. With the power off, or unplugged, place the paper in the shredder and look around where the middle of the paper (crease) lines up in the shredder. You might need a flashlight to help you located it. It will either look like a slot, or a little black lever.
Hopefully you will be able to blow the sensor out and clean it.
Good luck.
Jan 29, 2008 | Fellowes Powershred P-45C Shredder
Fellowes Powershred P-45C Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
