Question about Lucent ACT Netperformer 9360 Multiplexer (700061542)
Console cable pin out?
Does any one know the pin out for the console cable. I want to connect to my Netperformer console port to my PC com1 port.
  • networkmagic May 11, 2010
    Reliable information about this model appears to be rare...but it may be possible to determine the correct pinout based on the type of connector it uses. Some other Netperformer muxes use a DB9 male connector. What type of console connector does your unit have?
I don't know the Netperformer but several console cables are listed on AllPinouts (http://www.allpinouts.org).
AllPinouts is a Web-based free content project (like Wikipedia) that collects information about hardware interfaces of modern and obsolete hardware, including pinouts of ports, expansion slots, and other connectors of computers and different digital devices (i.e. Cellular Phones, GPS, PDA, Game Consoles, etc.). All text is available under the GNU Free Documentation License (GFDL) and may be distributed or linked accordingly. AllPinouts archive already contains hundreds of pages organized into three main categories (Connectors, Cables, Adapters) and several subcategories.
Posted on Apr 16, 2008
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
How do I open COM1 in Windows 7 Pro?
Com1 is the Communication Port. A serial Port located on the computer and usually 9 pins.
Feb 18, 2014 | Computers & Internet
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Lantronix UDS1100 what are the pin connection to emulate com1 on a PC
Please see the link here below for the complete manual.
http://www.lantronix.com/pdf/UDS1100_UG.pdf
If you go to page 70 you will see the complete pin layout for RS232, if you need to connect it to a PC with a 9 pin RS232 port you can see the equivalent on page 72.
Please let me know if you need more details.
Mar 15, 2011 | Lantronix UDS1100 (UD110000201)
Switch not connect hyper terminal
If you are connecting to the switch using the console port using a console cable. Make sure your settings for hyper terminal are on COM1 and the baud rate is 9600.
If you are trying to telnet, you will need to assign an IP address to the VLAN in order to telnet into the switch and configure a password or it will not let you in.
Mar 04, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
Need to reset, but don't know ID or password, no idea how to get into it. We got it from Verizon when they hooked up our 2xT1, but they refuse to manage the router. HELP!
That model isn't familiar to me, but try default login ID "admin" and Password "setup". If that doesn't work, the following procedure might allow you to log on and delete the config. That will delete everything, though, so make sure you read out all the configuration info before you reset.
  1. Connect the Console cable to the Console port on the Secure Router
  2. Connect the other end of the DB-9 Console cable to the COM-1 port on the workstation
  3. Start the Hyper terminal (VT-100 or equivalent) application on PC-1
  4. Configure the COM1 port for 9600 bps, 8 data bits, 1 stop bit, no parity, and XON/XOFF
  5. Login SR with the factory default login ID "admin" and Password "setup"
You can also reset those routers by deleting the config file like this:
  1. Login as above
  2. type "SR > clear cfg_file system.cfg"
  3. message will read "removing contents of '/flash1/system.cfg' ...done.
  4. now type SR > reboot
Jan 13, 2011 | Nortel Networks SR1004 4P ACTIVE T1 ...
2 printer on 1 pc
You can buy a Usb to Centronics adapter that installs the printer as can be LPTx, and have the printers you want.
Mar 12, 2009 | Zebra Z4M Printer
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
Jun 18, 2008 | 3Com Computers & Internet
Hyper terminal with IBM NWAYS Router 2210 Model 12E.
Hi Viki, I use HyperTerminal to configure my HP switches and a few other devices but typically they use a *special* manufacturer cable. I suspect that may be a problem you?re having; do you get any communications from the router via HyperTerminal? If you?re sure the cable is correct you can try the following configurations in HyperTerminal: -Start HyperTerminal *HT* with Com1 *if that?s what you?re using*connected to you console or data port on your router using the appropriate cable. - Create a new *location* in HT and name it something appropriate. - When the *connect to* box appears make sure you change the *connect using:* field to Com1 or whatever port you?re using* .-In the Com1 properties make the following changes: bps=9600; data bits = 8; parity = none, stop bits = 1 and flow control = Xon/Xoff. -Next click on file, properties then the settings tab. Set emulation to VT100 If this doesn?t work I would look seriously at your cable. Let us know if you have any more questions and as always please don?t forget to rate the posting.
Jan 16, 2007 | IBM NWAYS Router 2210 Model 12E
Lucent ACT Netperformer 9360 Multiplexer (700061542) Logo
640 people viewed this question
Top Lucent Computers & Internet Experts
John Anderson
John Anderson
D. E. Hev
Coss
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
