Question about Zanussi TC7114W Electric Dryer
The heat is there but it doesnt dry the clothes
The heat is there, it finishes the cycle and the clothes are stil wet?
    Scholar:
    New Friend:
  • 81 Answers
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Posted on Nov 27, 2013
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
My maytag bravos dryer is not drying?
sounds like your heating element is going bad
Jun 17, 2012 | Maytag Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Zanussi TC7114W Electric Dryer Logo
102 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
