Question about Kenmore Ovens
Harness wire to broiler element shorted out
How do I change the wire harness
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Magtag ser#mer6755aaw Broiler element not working.Switched wires from another element to verify that broiler element was working and it heated up just fine. Tried to get the codes to display but only got...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 15, 2011 | Maytag Ovens
My kenmore oven model 790.9622340C was on 425 bake and started making sparks like is you put foil in the microwave. I turned it off and looked inside and the broiler element had a hole in it so I was told...
yes they are solid wired together you may need to have the bake element but what has happened with your oven has been a massive short in the heating coil causing spark flame this must have caused a short in the temp control unit all the way back to the thermistate the oven really needs to be looked at by a service pro or you could /will end up replacing parts that dont need to be i have been doing this for yrs and in mu opinion you will save money by having a service man check whats shorted just have him/her check the elements and if there good then the control board thermals
best of luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Kenmore 47712 / 47714 / 47719 Electric...
Broiler will not shut off
no question you have a short in electrical . you do need a tec to ck this out . unless you have electrical expertise . it sounds like control panel or shorted( melted wiring ) mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore electric stove/oven model 911.9354591. The oven does not work. When in oven mode the broiler comes on. When in broiler mode, the broiler comes on. I have replace the EOC and checked for...
You probably know this, but on an oven unit there has to be two different phases of 120 to make it work. Check the wires that attach to the oven unit to make sure that you have 240 when in oven mode. If you have only 120, find out which wire is not hot and trace it to its source. Is it miswired at the other end? Is it shorted to one of the broiler wires? Usually there is a schematic to show how the oven is wired. Check for anything that is common to both oven and broiler wires and make sure the wires are on the right terminals. With out seeing the sove it is hard to know what it going on. Hope that helps. Robin
Jun 10, 2010 | Ovens
Gas oven(tappen) with broiler draw. oven will not light, no pilot
if this is fairly new, there is a hot surface ignitor near the back of the burner in the bottom part of the oven. This can go bad. There is a connector that can be pulled apart where the ignitor meets the wiring harness. Ohm out the ignitor or have someone with a meter ohm it out. There should be resistance and not open. If open the ignitor should be replaced. If you have a broiling element, turn that on. If the broil element comes on then the ignitor is almost for sure the problem.
Nov 21, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
14 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
