Question about Samsung SlimFit TXS3082WH 30 inch TV
Samsung txs3082wh convergence - Samsung SlimFit TXS3082WH 30 inch TV
Necesito el diagrama
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 19, 2014 | Samsung SlimFit TXS3082WH 30 inch TV
Another Question Please.
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
Flickering TV Problem
Some of their sets have a issue on the power supply board where it flickers(the picture) on scene changes and gradually gets worse.
problem with those sets is on the power board and some only require a jumper there to be removed.
Call samsung with the model number.
Jun 02, 2012 | Samsung SlimFit TXS3082WH 30 inch TV
My Samsung TXS3082WH 30 inc wide screen TV seems to be losing color and going in and out and i notice when you watch cartoons its fine but when it goes to actual shows or channels with normal footage it...
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
Jan 07, 2011 | Samsung SlimFit TX-S3082WH 30" TV
I can not adjust the convergance with the remote or TV buttons
Ur convergence is dead.Must change the convergence board.Buy the whole refurbish convergence at Tv repair world.com for the replacement.The Samsung/Akai use the same convergence boards.
Mar 23, 2010 | Samsung PCJ522R 52" Rear Projection...
I turned off the tv and when I turned it back on I have a picture but no sound. Please help. Samsung model#TXS3082WH
Check to see if the set is in Mute. Check to see if the speakers are turned off. Check to see if the volume is turned up. Go in to the menu and make sure the set is not in the SAP mode.
More than that, the set will probably require service to determine the cause of the failure.
Jerry G.
May 21, 2008 | Samsung Televison & Video
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Red convergence way off
I had the same issue as you pretty much exactly and so do others right around this last few weeks so I am thinking that this is a common problem with the product itself.
You can fix this pretty quickly with the link below. I bought it and it resolved the issue.
http://www.partstore.com/Part/Samsung/Samsung/PCN5425R/Samsung/Samsung/BP9500142E/New.aspx
Jan 02, 2008 | Samsung PCN5425R 54" Rear Projection...
POOR PICTURE
i have the exact same problem. mine has a yellow tint to it. im
Nov 25, 2007 | Samsung TXN3071WHF 30" TV
Samsung SlimFit TXS3082WH 30 inch TV Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
