Question about Vivitek D732MX DLP Projector, 3200 ANSI lumens Image Brightness, 2100:1 Image Contrast Ratio, 1.8 - 2.1:1 Throw Ratio, 1024 x 768 XGA native and 1440 x 1050 Resized Resolution, 4:3 Native Aspect Ratio, 16:9 aspect ratio support, 85 V Hz x 90 H kHz Max Sync R
Ballast uart error
I am getting a ballast uart error. What is the fix
  • Vivitek Master
  • 9,771 Answers
The ballast module controls the lamp operation. There is a problem with that module
Posted on Jan 12, 2014
I Cant Flash my Verykool s5028 Bolt - Failed: uart send error
  • Try different pac file
  • Reinstall USB drivers, try with different USB Port
  • Try Current version of Research Download tool
  • Read More
Oct 13, 2017 | Office Equipment & Supplies
Chevrolet aveo 2009 computer location thanks
Which one ? your vehicle has six different ones !
The scan tool accesses the following module data lines:
The electronic brake control module (EBCM) (UART)
The engine control module (ECM) (Keyword 2000)
The transmission control module (TCM) (UART)
The inflatable restraint sensing and diagnostic module (SDM) (UART)
The immobilizer control module (UART)
The anti-theft module (UART)
Sep 06, 2015 | Chevrolet Cars & Trucks
Replacing uhp lamp and remove ballast with Xenon lamp and 55W ballast!
You are going to ruin the optics using a Xenon lamp. The ballast in the TV talks back via UART to the CPU. By removing the ballast the TV cannot talk to it and run itself properly. Also using a xenon lamp will give terrible color reproduction as its not putting out nearly enough lumens in the right spectrum. It will also bombard the color wheel and DLP chip with UV light and ruin those as well.
Aug 30, 2015 | Mitsubishi WD Televison & Video
Screen shows blue box with 'software update through PC/uart
My bush bu11fvrsd32/X is show this on the front software update through pc / uart how can I get it of
Mar 16, 2014 | Televison & Video
Ballast uart
The ballast powers the lamp. Keep the old lamp. I think it will work once the ballast circuitry is fixed
Dec 18, 2013 | Office Equipment & Supplies
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
I accidently plugged something into the Service UART and now my TV doesn't work. What can I do to fix it?
The Service UART is used to make internal adjustments or updates to your tv. It is intended to be used by service technicians only.
Since you accidently plugged something into it, it's possible that an internal component has been damaged. Your best option is to call a tv repair shop have have a technician check out your tv.
Hopefully, your tv hasn't been damaged and the tech can get it working again. At the very least, the tech will be able to tell you exactly what's wrong with it and what it will cost to repair it.
Aug 14, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Ballast UART Error
Same thing happened to me. After one minute of running, lamp shuts off and 5 power led blinks and 3 ready led blinks, indicate UART ballast error. Well, I purchased a new lamp, and installed it, and the problem was gone. I looked closely at my old lamp, and it showed a little blister inside, and a tiny spot of white residue, perhaps it was the whole problem there, although I don
Nov 20, 2008 | Televison & Video
China mobile is not detected by pc
You need to install the software for that particular mobile so that your system detects the mobile. For eg. to work on a nokia mobile with your system you need to install the nokia pcsuite software...similarly u need to install the software for your china mobile
Feb 18, 2008 | Computers & Internet
Vivitek D732MX DLP Projector, 3200 ANSI lumens Image Brightness, 2100:1 Image Contrast Ratio, 1.8 - 2.1:1 Throw Ratio, 1024 x 768 XGA native and 1440 x 1050 Resized Resolution, 4:3 Native Aspect Ratio, 16:9 aspect ratio support, 85 V Hz x 90 H kHz Max Sync R Logo
264 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
