Question about GE JE1640WA/GA Microwave Oven
What are the dimensions of this microwave? - GE JE1640WA/GA Microwave Oven
I also have a Daewoo Microwave oven that quit working and I need a replacement. What Make and Model can I get that will be the same size for my motorhome.
get a tape measure and measure thea external dimension of the dead microwave
go to a retailer and measure the dimensions of new microwave ovens and one with the same or slightly smaller dimension will fit in
the power or wattage of the unit is of little consequence but don't get smaller than what you had but a a bit bigger will be good
Jan 05, 2017 | Daewoo Microwave Ovens
What are the dimenisons for the GE microwave JVM163WB004?
Jaquetta, best that I can find from GE's website is the following
Width: 29 7/8"
Depth: 15 1/16"
Height: 16 15/32"
Hope this helps!
Jul 18, 2014 | GE Microwave Ovens
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
What are the dimensions for the Frigidaire PLMV168 microwave oven?
Hello D Timmen - Dimensions
  • Width : 29 7/8"
  • Depth : 19 1/4"
  • Height : 13 1/2"
Nov 23, 2012 | Frigidaire PLMV168 Microwave Oven
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
