Question about GE Refrigerators
GE GSS22SGMC DONT MAKE ANYTHING, JUST POWER THE LIGHTS. I PUT THE COMPRESOR DIRECT AND START. I DISCONECT THE TEMPERATURE SWITCH AND NOTHING... WHAT YOU THING I MAKE TO DO?
Some day ago i put defrost heater and solenoid.
  • 8 more comments
  • Zejek Cantellops
    Zejek Cantellops Nov 27, 2013
    Sorry for come now..
    Well today i put the compresor direct and he start. (important)
    One tech come and say is the board but in other ocacion he say me de same with other problem and i check and find the problem is the defrost i put a new one and resolve it. Now he say that but i dont bealive... Sorry ... thanks everything for help.. John im ready to start.. What need make? Sorry for my english, i live in Puerto Rico and here just speak spanish...
  • Zejek Cantellops
    When i conect the refrigerator to the outlet just start the lights, compresor dont start, evaporator not turn on and the fan are in the back to refresh compresor dont start too... I check compresor direct and is good... What i need make now?
  • John Tripp
    John Tripp Nov 28, 2013
    If you have questions please let me know, John Tripp
  • Zejek Cantellops
    Zejek Cantellops Nov 28, 2013
    How i know the motherboard are bad?
  • Zejek Cantellops
    When i put the power outlet i hear a click in the motherboard but just one time and like a 40 seconds hear the click again... Them dont make click anymore... Now when i put the outlet he dont make any sound...
  • Zejek Cantellops
    I chek the motherboard and i dont see any solder bad. everything look good ... If you know how check are bad please tellme..
  • Zejek Cantellops
    Thanks!
  • John Tripp
    John Tripp Nov 29, 2013
    There really is not many ways to check the board for damage, unless you spot signs of heat damage or burn marks. Most times when tyhe board is bad it will show no signs of damage. Burned out motherboards is very common for the GE Refrigerator, Thanks JT
  • Zejek Cantellops
    Zejek Cantellops Nov 29, 2013
    Finally the problem is the board? Or i can check other part before replace the board? Thanks!
  • John Tripp
    John Tripp Nov 30, 2013
    Take your time Zejek. With the symptoms you said you have with this refrigerator the odds are the motherboard. Just make sure you have a good new start relay and run capacitor installed. Also insure the fan motors are healthy and not slow because these parts cause wear on the components of the motherboard. Or better yet bailout on the GE and replace it with a refrigerator that has no fancy control boards or digital controls. You will save in the end for sure! Thanks JT
  • GE Master
  • 4,654 Answers
I believe the most likely reason is a failed=> WR55X10942 Main Control Board
GE GSS22SGMC DONT MAKE ANYTHING, JUST POWER THE LI - 54b85f37-75d0-4ea4-bf98-01f8c080930c.jpg
Sea Breeze
Posted on Nov 28, 2013
Testimonial: "How i know the motherboard are bad?"
  • 42 Answers
SOURCE: Freezer won't defrost
savey73,
I think I know what is wrong. First the defrost thermostat you are talking about I believe is the round metal type with possibly a pink and an orange wire coming out of it. That is not the defrost thermostat as most people know it. That is a defrost overheat termination thermostat that opens only over 140 degrees F, that is why your old good one and your new good one show closed at room temp. If you read on the outside of the metal cover you will find it has a L140 indicating the limit of 140 deg.
Now to what should be causing your problem. You should find on the evaporator coil at the top left side of the evaporator coil a part that has 2 white wires going into what looks like about a 1" long X 1/4" round plastic thing. That little white plastic thing is a THERMISTOR. If it is bad your defrost will not work. Sounds like that is the only thing you have not replaced. There is no polarization of the wires That should FixYa
supertechks
Posted on Nov 24, 2007
catriver
  • 878 Answers
SOURCE: GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Posted on Dec 20, 2007
catriver
  • 878 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
Posted on May 30, 2008
  • 1462 Answers
SOURCE: Refrigerator GE GSS22KGMDWW defrost failure
it could be that too much ice is forming for the heater to cope with. check the door seals
Posted on Sep 14, 2008
Sea Breeze
  • 4654 Answers
SOURCE: PTS25LBM GE Profile Defrost cycle messed up
The GE Profile Refrigerator has circuit boards and sensors are in the freezer that sends a signal to the circuit board to begin and end the defrost cycle. It is very possible the sensor or the circuit board are defective and will need replaced. I will help you solve this if you like. This refrigerator is complex and will take more discussion with you to complete the repair, I am here to help, let me know, Thanks, Sea Breeze
Posted on Feb 06, 2009
Wont work
try wiring it up with both the constant power and the switch power directly to your battery. if it works, then your switch wire inside the vehicle isnt a 12v output.
if it doesnt, then something is wrong with your head unit
Apr 26, 2017 | Kenwood KDC-HD455U
Compresor dont get current
Autozone.com has diagrams for free when you register your car on their site. You can test the low pressure cut-off valve downstream from the evaporator tank by disconnecting the harness from the switch and using a good size wire to loop into the harness.
If the compressor clutch kicks in, you have either low system pressure or a bad low-pressure cut-out switch. This is a test procedure. Even bypassing direct as you have done can risk damaging the compressor.
Besides Freon, compressors need oil, the right type, and a small amount. There are Freon cans which include an oil charge as well as sealers and conditioners to prevent or fix leaks. Remember that the system has a volume limit and more additives leaves less room for the Freon to work good.
If you have low pressure, it is possible that what is left is contaminated. Freon is a gas. Air is a gas. The system was suppose to start with Vacuum negative pressure by using a Vacuum pump(Loaner item). This means that total volume inside your hoses could be wrong. It is easier to understand when you consider the Freon changes back to a liquid and Air needs a much lower temperature to become a liquid. So you lose volume for the Freon to change back from liquid to a gas. It constantly cycles like this to make it transmit heat from the cabin to the outside.
I hope my solution is helpful.
May 28, 2012 | 1992 Jeep Cherokee Sport
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Condenser coil fan not runningon GE pds22scrrss
The fan can rotates freely even if there's no power to it(fan probably burn out).You can check if power is going to the fan motor by folowing the two wires fron the motor picking up power from the compresor connections under a black plastic cover on the side of the compresor.If you nave power going to the fan its needs to be replaced.
Apr 26, 2009 | GE PDS22SCRRSS Bottom Freezer Refrigerator
Unit not coming on. air isn't getting cold
First check the breakers for the condensing unit (outside unit) and the disconect outside by the unit (could be a breaker ,a pull off/on switch or fuses)If its ok , you should have 220 ,240 volts to the unit contactor (you'll see it after removing the cover on the condensing unit).When the termostat is in the cold position and the temperature its set is lower than the one inside the house the contactor should be pulled in and give power to the compresor and the fan.But if the termostat is in the cooldest set and the blower inside the house works and the contactor in the condensing unit is not pull in the problem is in the termostat or in the low voltage wire.
Apr 24, 2009 | Heating & Cooling
GE AGQ10AJ - Compressor not turning on
Most of the cases when tou heard a click on and off is aproblem with the compresor that goes off on overload, when the compresor try to start and is stuck , burned or the starting coil inside it is open it's overheat and goes off by the thermo bimetal switch.Also could be the capacitor, to check it you need a capacitor tester,but if you don't have it you can try to put anew one (no more than 10 $) and see what happend if still the compresor is getting hot and won't turn on it's burned, jamed or open , and you have to replce it ,if it's less than a year old it should be under warranty but if not is an expensive job and you better get a new unit.
Apr 15, 2009 | GE AGQ10AJ Wall/Window Air Conditioner
Not getting cold, condenser dosn't sound like it's working, I hear a clicking sound like a relay but nothing turns on after the sound
If you hear a clicking sound,probably is the compresor trying to start ,if the condenser fan motor work ,first replace the relay wich is not expensive ,if it doesn't work you have a bad compresor.
Apr 10, 2009 | Refrigerators
Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
Mar 10, 2009 | Directed Electronics 479V Remote Gen 2...
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
