Right side of screen starts of with thin vertical strips then goes blank
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
You don't want to hear this, but forget about it. Sounds like bad Y buffer board. Hundreds of bucks to fix. I fixed that on my 42" Samsung, but I only had to buy the part ($200). I worked on TVs for 20 years. You don't even want to try tinkering with a flat panel. They are like $100 for a 32" at Walmart.
Posted on Nov 27, 2013
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
  • 380 Answers
SOURCE: Green vertical bar on right side of plasma TV screen
You could have one of three problems. One is really expensing to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went back. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
Posted on May 27, 2009
  • 14 Answers
SOURCE: Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Posted on Oct 14, 2009
LG model 47LN5700-UH LED TV. There is a single thin vertical line on the screen. I have changed the LED/Power Supply board and LED strips. What might be causing the vertical line?
You have wasted your time and money. The LED power supply and LED strips are only the backlighting. The only thing that might fix is a situation where you have a blank screen with the sound working.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Nov 26, 2016 | LG Televison & Video
The right side of my screen at about 3 inches from the side has a vertical bar that is lighter in shade than the rest of the picture. It started as horizontal flickering lines contained in the vertical...
Hello
There must be some loose contact with the t'Con board of your tV. Just look for it. Just unplug and replugh all the strip wires goes to T'Con board. This must solve the problem to your Tv. OK.
Oct 13, 2011 | LG 42LC2D 42 in. LCD HDTV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Green vertical line on the right side of screen
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Navigation screen freezes GPS unit
I believe they fixed this problem with a firmware upgrade. Use Garmin's web updater to perform the updates.
Jul 07, 2007 | Garmin eTrex Legend Cx GPS Receiver
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
