Question about Charging & Starting Systems for Hyundai Santa Fe Limited
No power to starter
Tried jump nothing- plenty of power in battery not even a click when you turn key
  • 32 Answers
In my experience, those indicators lead my thoughts towards the starter. Is it possible you are assuming that there is no power to the starter? Perhaps there is power getting to the starter but ends at that point. When you turn the key if all your dash lights come on as normal, i would say you need a new starter
Posted on Apr 12, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Clean battery term..well...in and out coke cola works great reconnect tryagain...make sure terms are tight and shiny
Posted on Nov 27, 2013
No power when turning key
Battery is bad. Rapid clicking of starter selenoid is because battery does not have enough to hold spring down in selenoid when it sees the starter load. Battery only has a surface charge (nothing of power). Try a new battery or a jump. Should have lights first, then horn, then starter. If no lights, check all fuses.
Jan 20, 2014 | Yamaha YZF-R6 Motorcycles
Turn key on, but doesnt even click. battery and starter are fine
This may be due to a bad neutral safety switch, is this car automatic or manual transmission?
If automatic try to start in neutral and if manual try to locate switch on clutch pedal and use a jumper wire to jump connector for switch, NOTE; If switch is jumped car will start in gear with pedal not pushed down and car will take off so this is just as a test not a repair!!!!!, good day
Oct 14, 2012 | 1996 Honda Accord
2007 chevy cobalt ls won't start battery good starter good turn key nothing no click nothing all lites work on dash and radio works jumped starter with screwdriver turns. Over but won't start...
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Jun 06, 2011 | Chevrolet Cobalt Cars & Trucks
Turn the key and not even a click,checked the starter,the battery and cables and relay,all ok has 460 and is a 4sp manual,has power to the soliniod and nothing coming out to starter cable,replaced it and...
check your coil it could be bad. does it jump start? have the alternator tested. If it jump starts disconnect battery and if truck dies then alternator is bad. Best way to test is auto parts store hwever.
Oct 14, 2009 | 1987 Ford F 250
Having starter or starting system problems
i would normally say check the bat. connections but since you tried jumping it off i will lean towards starter solenoid.
Jul 02, 2009 | 2001 Boss Hoss BHC 190 Hp
1991 Nissan 240SX starter will not turn!
If you've applied 12VDC to the solenoid and it does nothing, not even click, then the solenoid is toast!
Mar 22, 2009 | 1989 Nissan 240SX
1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
Feb 10, 2009 | 1995 Toyota Tercel
Won't start
if you have power and can turn the key and hear a click and your power is not lost than it is your starter it is bad or stuck.. you can try to hit it with a hammer SLIGHTLY. and try to knock it loose and see if it doesn't turn over then. if it doesn't than you need to replace the starter. you might also have someone turn the key and get under the truck and listen for the click you will be able to hear the starter click. If you hear it and your truck doesn't start than what is happening is it is engaging the spindle but not the gear.
Aug 03, 2008 | 2002 Ford F350 Super Duty DRW Reg. Cab
Charging & Starting Systems for Hyundai Santa Fe Limited Logo
79 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
