Question about Acer Aspire AZ1620-UR31P G530 All-In-One Desktop PC w/ 2GB - 500GB
Graphics card i was wondering if i can change the graphics card on my computer s that i may have 2 moniters?
  • 78 Answers
No need. because the on board vga pin won't work after inserting a graphics card. if you want to connect more monitors, you better buy a vga-splitter (1 into 2, 1 into 4, 1 into 10 . . . )
Posted on Nov 27, 2013
Ok, I changed my video card ( hp: p6230f) I still have no signal in your opinion would you go with monitor failure or motherboard? I have also checked all connections. Soon as I turn it on it scans reads...
1.If your display come during start up windows then its problem with graphic settings.
2.check moniter with another pc if its work on that pc then its your card problem.
In the case of 1 you have to go in safe mode and change the graphic setting.you have to change frequency hertz from advance setting to 60hz or 75hz which is mostly compatible with all moniters.And restart pc.you also check display driver correctly installed.
in the case of 2 problem change card or connec it with built in vga card and check your graphic card with another pc.you should find what is problematic by follow these steps.
Jul 13, 2011 | Computers & Internet
Turn on my computer, I can hear the fans, no beep noise upon starting. Screen says no signal found. I tried other monitor cables and monitor. No dice.
one of 2 things is happening a) if you have changed the cord and tried other moniters then the display port beit vga or dvi on you computer is broken you will either if you have agraphics card already installed then replace that but if you have no dedicated grapichs card you need to replace the mother bord
B) check your moniter to see if there is a source button if there is then push it to see if the image comes up repeat up to 3 times
ps: if you have a dedicated graphics card look at the back of you computer and if there are 2 different display ports be it dvi or vga (google image the terms "vga port" and "dvi port" to see what they look like) then plug it into the other on to see if the graphics card is broken
May 02, 2011 | Sony VAIO PCV-RZ56G PC Desktop
My computer screen goes black alot, sometimes white with weird microsoft ballons of misc information in the background. I changed moniters but it doesn't solve the problem. Where is the video card...
The problem is not on the monitors, but came from you AGP card, The video card located on AGP slot, try to release and plug again, if the problem still the same, replace your graphic card
Oct 20, 2009 | Gateway GeForce2 MX400, (64 MB) AGP...
Graphic Card Problem
there could be many things besides the graphics card. To start however, make sure your laptop recognizes your card and its drivers installed. Make sure your card is compatible with your motherboard. what is the model of your graphics card?
Dec 12, 2008 | Intel D101GGC Motherboard
GeForce FX 5200
If your video card was not working correctly your problem would be evident in other applications as well, I suspect you have a software problem on the computer, most likely with the OS 10 software and possibly a conflict with the version of Quark you are running.
Oct 28, 2008 | Apple iMac G5 Desktop
Computer Moniter screen turned purple
This is a problem with the video cards hardware or the driver itself depending on your card you should updaate your cards driver from the appropriate site,right click the desktop>properties>settings>advanced>ada... will then see the name and manufacturer of your graphic card
go to the appropriate website and download the latest driver,here are the three main graphic card manufacturers websites
1) nvidia.....http://www.nvidia.com/Download/index.asp...
2)a.t.i.....http://ati.amd.com/support/driver.html
3)intel...http://support.intel.com/
other things to check are
1.make sure your graphic card is securely fitted and if power is required to the card,then check the power connector is securly fitted and inserted
2.try changing your monitors lead from the v.g.a connector to the d.v.i connector at the back of the card,the v.g.a. is a blue connector and the d.v.i. is a white connector,and the d.v.i requires a d.v.i to v.g.a converter
3.where applicable install any monitor drivers however these are rarely required
4.run the direct x diagnostic utility,press start>run>type dxdiag >press enter,then go to the display tab and run the "test direct 3d" test
5.finally check all cables are securly fitted
if after these tests and tasks you still experience problems then change the graphics card and run the tests again,if you experience more problems then a new video/graphic card is required
any problems let me know
good luck .......
"Don't forget to rate the solution"
May 28, 2008 | Gateway FPD2275W LCD Monitor
Unclear fonts and images
Hi
Pls reinstall the drivers for the graphics card and restart the computer and check if it is working.
If it does not work, then download the original drivers from the computer manufacturer or the graphics card manufacturer 's website and install them. Make sure that you have uninstalled the drivers before reinstalling any drivers.
Also pls look for any updates for the graphics card.
Feb 26, 2008 | LG Studioworks 45 14" CRT Monitor
Acer Aspire AZ1620-UR31P G530 All-In-One Desktop PC w/ 2GB - 500GB Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
