Question about D-Link Dap-1533 Wireless Access Point DAP1533
Reset dap 1533
How do I reset DAP 1533 to factory defalts
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Posted on Jan 04, 2010
  • 11 Answers
SOURCE: i can't find ip adress
The device communicates with the computer devices least displaying details. For example, setting up the router modems requires connections also from where the computer adminstrator sets the passes least disclosing detail IP addresses.
Posted on Apr 04, 2011
  • 10 Answers
SOURCE: Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Posted on Oct 12, 2012
How to configure dlink dap 1160
Ashraf, you could contact the manufacturer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
DAP 1160 Wireless Access Point
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201160/Manual/DAP_1160_B1_Manual_v2_00_EN.pdf
How to factory reset your Link router
May 06, 2016 | AccessData Password Recovery Tool Kit (ftk...
How to change password?
If you can't remember the password, follow these directions to reset the access point to factory default. You can then log in with a username of admin and a blank password.
DAP 1360 Wifi Access Point Hard Reset PCingredient
If you know the current password, just log in and change it on this page
http://www.support.dlink.com/emulators/dap1360/101/tools_admin.htm
Nov 09, 2015 | D-Link DAP-1360 Wireless-N Range Extender...
How can I connect to my new WiFi using my dlink dap 1320 thru my Samsung tablet, how can I reset the old one
You need to get the Wireless Range Extender to communicate with your existing router. Instructions are attached. If you have already done this, you should be able to search for WiFi connections and connect to the SSID with your password. It should be the network that has the most strength. In Canada, you can contact Dlink at (800) 361-5265. In the US, (877) 453-5465.
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/QIG/DAP%201320_QIG_US.pdf
Feb 03, 2015 | Samsung Tablets & eReaders
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
Mar 19, 2014 | Computers & Internet
If you have forgotten this password, you will have no choice but to reset the router to factory defaults.
Reset Procedure: With the router powered on, Press and hold the reset button (on the back of the router) for 10 seconds and release. The lights on the front of the router should all flash and reboot.)-
Mar 10, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Reset a D-Link DAP 3690
There should be a little button on the back to reset to factory defaults. Sometimes it's hidden behind a little hole and you have to poke the tip of a pen in it, hold it for a count of 5, and all the lights will blink and it will be reset to factory-new.
Jan 06, 2014 | D-Link Network DAP-3690 AirPremier N Dual...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I can't find ip adress (192.168.0.50) because i'm not sure to proceed factory reset on DAP-1353
Apr 04, 2011 | D-Link DAP-1353 Wireless N 802.11n...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1522 up as a wireless bridge. My current internet provider is Verizon Fios using their router. Why can't I...
Assuming that all settings are still at factory defaults... It's likely that to connect to the device through the web browser or through the app, you will have to temporarily assign your PCs network card a static IP address that is in the same range as the router (for example: 192.168.0.10). The user name should be admin and the password should be left blank. Make sure to plug your router directly to your PCs LAN port with an ethernet cable.
This article on the extremetech website explains exactly how to do what you are trying to do:
http://www.extremetech.com/article2/0,2845,2329231,00.asp
In case the previous link has too much info, here's another site that simply tells how to access the manual settings of the router through the browser: http://www.paraesthesia.com/archive/2010/05/04/connect-to-the-d-link-dap-1522-access-point-configuration-manually.aspx
If you go through these steps and still can't communicate with the device, it's likely that router's default configuration has been modified and you will have to reset the router to factory settings to get it back to the defaults. Then you may proceed as listed above.
To reset (if necessary) follow these instuctions on the D-Link website:
http://www.dlink.cc/d-link-wireless/d-link-dap-1522-forget-password-you-will-have-to-reset-it-to-factory-defaults.html
I know it's a lot of stuff, but I hope this helps. It can be frustrating, but you'll get through it.
Steve G.
Mar 01, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
D-Link Dap-1533 Wireless Access Point DAP1533 Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
