Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Microwave is heating but the fan is not blowing
Unit sparked at some metal now there is no airflow in the unit. The unit seems to still be heating but I am afraid to run it
  • 2,113 Answers
Just replace the shaded pole motor with any other shaded pole motor that you can put in.. new or used
Posted on Nov 27, 2013
2 Suggested Answers
  • 949 Answers
SOURCE: fan runs when unit is off
The control relay has gone bad, to replace this if you can find the board runs about $195.00, I hate to say do not repair something but in this case, I would have to say it is time to retire this one.
Posted on May 13, 2010
Why Auto fan seems to go on prematurely
The vent fan comes on if your steaming or creating heat unit it to protect the control unit. So I assume this was happening when the fan came on? I hope this answers your question. When this happens the unit will turn off when it cools down all by itself.
Aug 02, 2014 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
As plugged in microwave starts up doesn't stop even if you press clear and it also sparks where can i go to exchange it or have it replaced?
Sounds like someone tried heating something up with metal attached or possibly left a utensil, Chinese food with the metal handles or foil in the unit - throw it out and but a new unit - it's not worth it parts plus labor and it will never work right again the power scale will be off
Jan 14, 2013 | Emerson MW8777W Microwave Oven
I have a GE Spacemaker Microwave DE68-40861A that has a built in range vent. The fan motor blows just fine, but there is no airflow. Apparently this was installed improperly. What would be blocking the...
take microwave down. There is 1 screw on the back that hold fan in. Pull screw out and the fan will lift out. Roll fan so that opening of fins faces to the front. set it back in put screw back in and remount microwave.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Its runs but no heat.
It is usually the magnetron tube that fails which then blows an inner-cabinet fuse. The world seems full of bad Asian made magnetrons that fail prematurely due to air infiltrated internal vacuums from leaking metal to glass seals. It will probably cost more in parts and labor to repair than a new unit. A well made magnetron should gradually lose output power over time (years), not just quit. Hope this helps!
Apr 06, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Sep 08, 2009 | Microwave Ovens
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Humming and sparking inside the microwave
Sounds like you have metal inside oven, and arching can happen if nothing is in there to absorb energy.
Mar 15, 2009 | Microwave Ovens
Intermittant heating
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
Jan 05, 2008 | Maytag MMV5156AAS Microwave Oven
Sparking / Popping Microwave
GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touhc with a local authorized servicer.
Apr 01, 2007 | GE JVM1650 1000 Watts Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
