I want to clean filter
I cannot locate any filter either inside or outside the machine
    Scholar:
  • 171 Answers
Try this site .... http://voices.yahoo.com/cleaning-washing-machine-filters-yourself-1817933.html
Posted on Nov 27, 2013
How do you clean the filters on the outside unit of split system Mitsubishi reverse cycle 18RV
Outside unit does not have a filter. You can try to pull the disconnect on the outdoor unit. Reinsert after 10 seconds, see what happens.
Jul 08, 2017 | Mitsubishi Heating & Cooling
Tip
Lower the cost of your Central Air Conditioning Bill
Dirt is the enemy and your defense is simple and inexpensive.
Central air conditioning units are simple machines which take the warm air from inside your home and put it outside. There are two parts that do the bulk of this 'Heat Transfer", they are the inside coil and the outside coil. A coil that is covered with dirt does not transfer heat very well.
The outside coil is the outer layer of the unit located outdoors. First, shut off the power to the unit. Clear any weeds or decorative plants away from the machine. The machine should have a good 18 to 24" of clear space around it. More is better. If possible, nothing but blue sky should be above the unit. Although there are special detergents used by commercial contractors, I have found that in most residential locations, using a simple garden hose to wash the spaces between the aluminum fins is adequit. If you find that the fins are blocked, you should have a professional coil cleaning. While you are at the unit, take the time to straighten any fins that are bent over. Again, if a large area is bent and you find that you are damaging the fins, call a professional as they have special tools.
The inside coil is not so easy to access. For this reason, a high quality indoor air filter is recommended. Many people use carboard encased fiberglass filters, which cost about $1.00 each. Much better to go with a pleated media filter, even better, one maked high efficiency. Change it whe the surface is covered with a fine, even layer of dirt. Some homes will require monthly changing, most will need it every 3 months and a few will only need it once every 6 months. The Glass Fiber filters only catch the very big pieces, allowing the small particles of dust to flow into you indoor coil. WHile operating in the air conditioning mode, the inside coil is wet. This is because part of the process of removing heat involves removing humidity. WHen the fine dirt mixes with the moisture, a fine mud starts to build. If allowed to continue, the deminished air flow will result in poor performance and will require a professional cleaning that can take as much as 12 to 16 hours and involve extra charges for equipment involved in protecting the environment. In a worst case senerio, low air flow can cause the compressor to fail. Those 'Expensive" filters really are a bargain.
on Jul 19, 2010 | Heating & Cooling
Where do I locate the filter on clothes dryer - simpson ezi set 350
The filter is located inside the dryer at the back of the drum. There are two holes that you can pull on to release the filter.
Here is a YouTube video that shows where the filter is located.
https://www.youtube.com/watch?v=E3r7J5j_I14
Nov 27, 2013 | Washing Machines
Clean the Lint Filter or Condenser
check inside it may have a lot of lint build up in it, check the vent to outside and be sure there is no sharp bend in vent pipe to make it over heat. the straighter the better !
May 09, 2012 | Dryers
Where is the filter to clean on the Hotpoint WMA64 washing machine
Filter is located at bottom rear of washer.
Remove lower rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Jan 03, 2011 | Washing Machines
Were is the termal fuse located on a kenmore 70 series dryer?
if the filter is on top then it's in the rear,if the filter is inside,remove the bottom panel,remove the lint filter and then remove the duct that the filter slides into,you'll see the thermal fuse located on the top right hand side of the blower wheel housing,if the fuse is popped then you need to clean out the dryer and the vent line or it will keep popping until it's cleaned,clean out the duct that the filter slides into,remove the vent line from the back of the dryer and if it's a long run blow it out with a leaf blower,make sure the outside hood is clear first so the lint will blow outside and vac out the inside cabinet where the motor is,mkae sure the dryer is unpluged before you go into it and when checking any part with a meter at least one of the wires have to be removed or you won't get a correct reading.let me know how you make out
Oct 30, 2010 | Kenmore 73952 Gas Dryer
Our dryer is not starting at all when we push the start button. Door is closed, tried the breaker...no luck. Any suggestions?
first check the door switch,push the paddle in and out,if it doesn't click you have a bad door switch.if that's ok check the thermal fuse,if the filter is on top of the dryer the fuse is in the back if the filter is inside the fuse is in the front located on the blower wheel housing.if it's the thermal fuse most likely you need to clean out the dryer.remove and clean out the duct that the lint filter slides into,vac out the inside of the dryer where the motor is and clean out the vent line and the vent outside.if it's a long run from the back of the dryer to the outside i use a leaf blower to blow out the vent line.the part number will be a 3392519 if it's a round thermal fuse it will be a 3390719,these are the most common thermal fuses,next time send the model number and i can look up your machine,let me know how you make out.if you don't clean the dryer the fuse will pop again
Jul 20, 2010 | Kenmore 67632 Electric Dryer
Just purchased a home and was never told where the air filter is
Well if it not in the boot looking thing coming off the side of the furnace then it is most likely inside the furnace.
Jan 01, 2010 | Heating & Cooling
4E error....samsung J845
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
? filter change
The filter is located at the rear of the m/c, remove lower rear panel, and u will see a large black hose on the right, remove clip and hose ,inside u will see the filter, remove and clean ,refit making sure u get the hose on properly.
If your outlet pipe goes into the sink waste, remove connection and clean inside.
If it goes into a stand pipe make sure it is clear at the outlet end where it goes outside.
Also if u do not already do this, put the washer on a very hot wash with powder in but no clothes and let it do a full prog.
This is called a maintenance wash, and should be done 4 to 6 times a year, this helps to keep it clean and stop it smelling.
Also make sure u are using sufficient powder, and not washing everything at 40oC.
Plz rate my sokution.
Thanks.
Jan 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
