Question about Samsung SyncMaster 2253LW Monitor
VGA Will not connect
My VGA Cable on the Samsung SyncMaster 2253LW will not connect to my Mac, though it just started acting up. I tried everything I read but nothing will come up. When I change it to Digital it comes with a floating box that says Check Signal Cable, but when I click source it gives me a black screen with the power button blinking.
  • Samsung Master
  • 7,993 Answers
Have you checked if the SyncMaster is compatible with a Mac? I do not use Macs, so I do not know. In the old times you had to buy everything Apple. You could try looking for an adapter to convert VGA or Digital to Mac Video.
Posted on Nov 27, 2013
Testimonial: "It did work with my mac. It was working fine before. I already have a adapter for VGA to my Mac, but not DVI yet."
4 Suggested Answers
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
  • 80 Answers
SOURCE: Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
dhecom
  • 233 Answers
SOURCE: i have the Samsung Sync
did you try other VGA cable? because this usually happen went you using bad cable.
dm
Posted on Aug 10, 2010
How do you disassemble a syncmaster 2253LW monitor?
Most of these have clips and little screws. Use athe smallest screwdriver you can find slip between the seams and easy pry it just enough to see in to find the other clips slowly work your way around it. Till it pops off.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
Samsung syncmaster 794mg monitor setting
i want vga cable D connecter connection
mainly vga cable broken that why i purchage one emitty d connecter scoket so i soldering this connection plz
May 23, 2011 | Samsung SyncMaster 793MB 17" CRT Monitor
My Samsung SyncMaster 2253LW Monitor can't auto adjust problems
if your using a DVI cable instead of a VGA cable you won't need to auto adjust anything because it is done automatically when using a DVI cable. a DVI cable looks like this and a VGA cable looks like this
Apr 30, 2011 | Samsung SyncMaster 2253LW Monitor
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
My screen has horizontal lines apprearing in gray on a black back it has started after 6 months of use... and its has become anoying... could it be the wire?
Yes
1. this may be a internal loose ribbon cable or the VGA cable it self.
In any case you will have to have it looked at.
2. Check the pins on the connector end of the monitor. make sure none are bent or broken or loose.
Make sure the cable is secured to the video card.
4. Make sure you have the video card settings to the proper resolution. They could have changed.
If the monitor is 3 yrs old or more and it may need driver updates. check the manufacturers site to see. Via model number.
May 29, 2010 | Samsung SyncMaster 2253LW Monitor
I have two Samsung Syncmaster 2253LW monitors. One is about two years old. The other one is new. The older monitor seems to be darker than the new one. How can I restore the monitor to the original...
open the monitor look there is an eht a black big part has a preset rotate it with a screwdriver in on condition of monitor then you can regain the original brightness
Mar 21, 2010 | Samsung SyncMaster 2253LW Monitor
The Digital wire on the moniter for Samsung Syncmaster 2253 LW is not working anymore. Right now i have to use the old style moniter plugs.
If the old style connector (VGA) is working, you can use that. For single monitors under 24" wide, the difference is not noticeable.
Mar 04, 2010 | Samsung SyncMaster 2253LW Monitor
I want to remove the stand from my samsung monitor (2253LW)
Hey! I figured it out, Do this gently, but with the stand all intact, you can pull it right out of the monitor!
Apr 03, 2009 | Samsung SyncMaster 2253LW Monitor
Samsung SyncMaster 2253LW  Monitor Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
