Question about Dell 1600n All-In-One Laser Printer
Paper jams this is my primary problem with the 1600n all in one printer. The standard multipurpose paper in the paper tray gets jammed every time it is pulled in through the printer. what can be done? Also, the rollers to pull paper inside the top (for faxing/scanning) gets stuck most of the time.....it pulls half way then stops - leaving the paper jammed.
Often jammed after a few pages into an auto-feeder scan.
Solution:
1. Remove the roller assembly including the metal bar from the machine. You need to release the locking key (light blue) first.
2. Spray 409 cleaning solution on a paper towel; wipe on surface of the two rubber rollers along their axes.
Yeah, the rollers that the warning sign says not to touch.
I guess the warning sign is to prevent you from contaminating the surface. But if it is already contaminated, then the 407 will decontaminate it.
Posted on Oct 30, 2007
    Scholar:
  • 121 Answers
It sounds like you'll need new feed rollers.  I could find some part #s for you if you felt confident replacing them yourself.
Posted on Oct 26, 2007
SOURCE:
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Mar 14, 2008 | Dell S2500 Printer
Dell 1600n All-In-One Laser Printer Logo
177 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
