Question about Canon Office Equipment & Supplies
I was printing with my Canon MF4100 Series UFRII and it is stuck printing the same page I had printed a week ago no matter how many times I tell it to abort or cancel all printing jobs. Is there an internal memory that can be cleared. It's also asking me to reinsert the paper cartridge and click OK on the unit each time then that same page prints. Started happening as soon as I pulled up an entirely different job to print. Before, no problem at all. Till now it's been the first printer I've owned in 20 years with not one hitch. HELP! Thanks
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
websnail
  • 419 Answers
SOURCE: unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
websnail
  • 419 Answers
SOURCE: printer will not cancel print job
START
Control Panel
Services
  • 10 Answers
SOURCE: Canon MF4100 Series UFRII LT print problem
sounds like an error with the printers ink cartridge reader
Posted on Jun 18, 2009
SOURCE: i canceled a print job and it says it is deleting
If you haven't tried restarting your computer, do that first.
If that didn't help try to restart your print spooler.
Click on your start button and then on Run.
Type services.msc and then OK. In the services window find Print Spooler.
Double click it to open, it should say started. Click stop, wait for it to stop, then click start again. This should clear out your job.
Posted on Nov 24, 2009
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
Feb 16, 2011 | Canon imageRUNNER C3220 Color Copier
What do we need to purchase to make our IR 3025 network capable?
You need to buy UFRII printer kit for net. printing, and send kit for Scann to e-mail, scan to folder,...
In Europe we cant order any more kits for this product!
Jan 13, 2010 | Canon ImageRunner 3025 Black and White...
My canon mf8100 series prints once, then beeps and
set the paper size to A4 in ur computer and in ur printer
Aug 29, 2009 | Canon MF8180C Color Laser MFC Printer
Jun 18, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4100 Series UFRII LT has paper jam after i accidentally turned off the printer while it was int he middle of printing. The LED screen on the printer says "Paper Jam" then "Lift panel to open open...
just press the resume button and if the problem presist switch off your printer and computer and again restart both of them. and if still paper jam then press resume button.
Feb 27, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
No printing on Mac OS 10.5.1
Check under the Apple site for this issue. I use Leopard and can copy and print with this machine. I have not tried the fax, however, I assume  it will work. The scanner does NOT work with Apple...at least yet...I am not sure if it is Apple or Canon or both who are at issue for this. As per the post below, the duplex works just fine for me. You may want to consider the possibility of removing the current drivers and reload the one's currently posted by Canon.
Duplex Printing
Apr. 19, 2007
Archon Fung
I figured out how to make duplex printing on the MF4150 work! Canon Tech support says that duplex printing is not supported, but they are mistaken.
Here is what you need to do:
1. go to the Canon site and download the latest UFRII driver (v1.5) and install it
2. in the application, go to page setup and select "Format For:" MF4100 Series [this was what I did not realize]
3. then, when you go to print, select the finishing tab, and then select 2-sided printing.
If you skip step 2, and you application defaults to "format for any printer," the 2-sided option will be greyed out. Other printer drivers do not require this, but the Canon driver does.
Nov 26, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
146 people viewed this question
old marine
old marine
