Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
No power to thermostat inside the house
Can not get any power to thermostat inside the house to turn unit on
  • 2,113 Answers
Replace the 24 volt ac transformer mounted on the side of the furnace
Posted on Nov 26, 2013
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
nope, nope, sounds like a stuck contactor in the electrical compartment of the condenser, but there are actually several things that could cause it.
Sep 30, 2009 | Heating & Cooling
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
The air conditioning unit outside is running but there is no cold air coming into the house. I hear the inside unit turning off and on but no cold air. I also smell a burning odor. I have turned off the...
if unit is going on then off within a few minutes needs service can be needing freon,outside dirty causing overheating,power supply if 220 not getting full power ,to compressor going bad
Sep 26, 2009 | Goodman CLQ36AR49 Air Conditioner
Air conditioner does not kick on when I turn down the thermostat
What kind of a unit is it? Is it integrated with a furnace in the attic? Need to now this information. Also, turn the thermostat to Cool/Auto and go outside to see if the condenser unit is running, if so, then there is a problem with the indoor blower motor or thermostat. Jumper the green and red wires on the thermostat and see if the blower comes on. If so, you have a bad thermostat. If not, you could have a bad fan motor or capacitor.
Jul 08, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
My blower inside my house will not come on. outside unit either
Initially, it doesn't sound like your thermostat is working.
If it has a setting to allow the blower (air mover) to be operated alone or continuously, try that.
Generally, if the inside unit (air mover) won't power up, the outside unit will not turn on for more than a couple of minutes because if the inside unit isn't working, pressure builds up in the lines going to the outside unit and an over-pressure sensor will shut it down again.
Jan 09, 2009 | Friedrich QuietMaster Electronic SS12J30D...
Thermostat install for 1989 Maxima
it goes inside of the housing unit. but when you put the housing unit on, the stem should be pointing to the engine
Dec 02, 2008 | 1989 Nissan Maxima
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Central air conditioner doesn't turn on... Any suggestions?
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation. If your central air conditioner doesn't go on automatically: 1) Be sure the thermostat is set to "cool" and set below room temperature. 2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse. 3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off. 4) Turn off the power to the air conditioner and check the thermostat. 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. 6) Turn the power back on. 7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
