Question about Uniden BC244CLT Base Scanner
All lock out, how do i unlock it
My scanner seems to be stuck on lockout, help
How do you unlock channels on scanner
Hi Lori,
Many times, you need to switch to MANUAL mode (out of scan) and step thru each channel. The display will indicate if the particular channel is locked out by symbol or text. Pressing ENTER or LOCKOUT (depending on model scanner) should toggle a locked out channel back into the scan - and a scanned channel into lockout.
Without knowing your scanner model - it's difficult to tell you exactly how to do it. If my suggestions do not work, reply and include the brand and model number so I can get you the exact steps to solve your problem.
May 29, 2013 | Uniden Radio Communications
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Kenmore dishwasher 665 lockout problem
You may have a bad control console.
Jun 20, 2009 | Kenmore Dishwashers
My scanner is stuck on ''all chanels locked out'' I don't know how this happened. I have tried resetting and iitializing but nothing is working.
If you reset and/or re-initialized the scanner, then you quite possibly have deleted the frequencies you had programmed in it. Can you see any frequencies showing when you have the scanner in manual mode? If so, try pressing the lockout button, which usually is marked with something like L/O. If L/O appears on the screen, then that channel is locked out. Press the L/O key again to unlock it.
Jun 05, 2009 | Radio Shack Pro-2096 Base Scanner
Lockout message
Uniden has a webpage with a free manual pdf download for your scanner.
You'll be able to get the manual HERE The link is upper right side of page..
If all your channels are locked out, press and hold the l/o button for at least 2 seconds, you'll hear 2 beeps and that should unlock them.
May 23, 2009 | Uniden BC120XLT Handheld Scanner
We have a handheld radioshack 1000 channel scanner. All channels are locked up. How do we unlock?
try holding the LO (lockout) button down for a few seconds and it will probably unlock all the channels on the bank its locked up in, then move to the next bank of channels and do it again
Dec 25, 2008 | Radio Communications
Channel lockout on Regency D300 scanner
While in SCAN mode, enter the number of the channel you want to lockout. To re-activate it, enter the channel number again.
Oct 30, 2008 | Uniden BC72XLT Handheld Scanner
Just bought this scanner used and having problems with Banks 3 and 4
while the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Sep 05, 2008 | Uniden BC80XLT Handheld Scanner
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Aug 19, 2007 | Radio Shack Pro-94 Scanner
Uniden BC244CLT Base Scanner Logo
49 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
