Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
My up right freezer in frosing at top inside part of the unit.
    Top Expert:
  • Kenmore Master
  • 12,962 Answers
Frosting on evaporator coil should be evenly distributed all over the coil. If the frosting only appears up on the top around where the refrigeration line enters then the gas pressure is too low - if you add refrigerant the frosting will move down to cover the bottom coils also.
Posted on Nov 28, 2013
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
We have a true single door freezer, it is iced up inside . what should the dial inside the unit be set on.
On the freezers a setting of 7 or 8 should do fine. I would be more concerned with the defrost timer, defrost heater, and settings. Also a HUGE problem is that the door switch on the top center of the door can sometimes barely contact the door (this happens when a unit is slightly warped or out of level) or the spring loaded hinge on the door can break causing the door to stay propped open at times. When the door doesn't close the evaporator fan stops but the compressor will continue to run. I have had to tape a nickel on top of the door to make better contact with the switch. Make sure the switch isn't the problem before going any further.
Nov 17, 2010 | True 23 cu. ft. / 651 liter Commercial...
After turning the freezer off to defrost it noted the top and sides got pretty hot.Is this normal?
yes it is as most units have a heater around the doors and inside the unit to aid in defrost and to help keep the unit frost free
Aug 09, 2010 | GE Freezers
Amount of refrigerant that carries this freezer is 1.6 pounds? "
Those freezers utilize R-404A refrigerant. The amount of refrigerant will be displayed on the data plate on the inside of the unit usually on the left inside panel. It will have the type and weight of refrigerant...
However, yes, 1.6 lbs sounds about right for those models.
Jun 06, 2010 | True 52 cu. ft. / 1472 liter Commercial...
Wanting to know if I can move a freezer right after unplugging it? Or does one have to leave it sit awhile first?
Refrigerators or freezers can be moved right away as long as they are empty and the doors are secured properly. Frozen objects left inside a unit can damage the interior and should be removed. Be Gentle... Never drop it or shock it in any way when unit is still frozen inside. Be careful if using a hand truck or dolly as care must be taken to avoid damaging the condenser coils either behind or underneath a unit. Lastly, wait 5 minutes before plugging the unit back in so that pressures may equalize in the system. Good Luck!
Jun 04, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
How do I get to the evaporator coils in freezer
You have to remove the rear panel inside the freezer compartment by taking all the screws off and pulling the top of panel upand towards you.After that you should see the components Hope that helped :)
May 12, 2009 | Freezers
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
What can I do to get rid of frost build-up (more than 8" long & 1/2" Deep) on my NEW FROST FREE FRIGIDAIRE FREEZER GLFU2067F?
contact 1-888-77-lowes if you havent done this call, have them create a case file on this, tell the person that you talk to that if you try this solve and it dont fix the issue I want a new machine if they agree to this do the door replacement if they don't take it back to lowes
Mar 25, 2008 | Frigidaire 20.3 cu. ft. Upright Freezer...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
69 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
