Question about HP R3000 XR (AF414A) UPS System
Tape Alert [11]: The voltage supply to the library is outside the specified range.
I did a self Test on a R3000 XR UPS and have been recieving the following message on each job that runs. The UPS Management software shows no change in the power out and Load (at 50%). Tape Alert [11]: The voltage supply to the library is outside the specified range. There is a potential problem with the power supply or failure of a redundant power supply. Thank You
Paeroa
  • 457 Answers
SOURCE: harddrive self test
I did a google search to see what results I would get for your request "failed #1-07 none of them who enquired to this problem spoke of the number that came up for you?. But they spoke about not being able to BOOT up to Windows in fact all of them said it!. Thats normally a BIOS update needed. But there was one other person who gave this message which might suit you wellllll at least it wont harm you he said this "Download the diagnostic utility from the HD maker and see what exactly is wrong."
Posted on Sep 06, 2007
info2u
  • 596 Answers
SOURCE: SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Posted on Feb 09, 2009
  • 439 Answers
SOURCE: Get the following error message: Scanner Failure
It means that the printer is having problems powering the scanner, either the light source is not working or the belt drive or gears are jammed. It is a self diagnosis that is not passing. That is the reason for your problem.
Posted on Jun 21, 2009
  • 26 Answers
SOURCE: ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Posted on Aug 01, 2009
  • 526 Answers
SOURCE: Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Posted on Jun 02, 2010
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
Self test failed
This could mean that you have bad batteries in the UPS. Usually when it does this test its to test the batteries. So the UPS will start a battery test, Rectifier will lower it's voltage to a set point where the UPS tell it self to go on battery. If the UPS detects that, the battery % is lower than the allow set point to perform the the self test it will stop the test immediately. This way your load is not interrupted. Also could be that the intelligent modules or power modules have a issue which again the set point is to low or out of range due to the total of load the ups has on the output compared to the total power modules that might have a problem with. The UPS is smart enough to stop its test and sends a alarm to notify you. Hope this helps. Get the manual and go into the ups and do a diagnostics on the UPS, this should identify if you have bad batteries or power modules are bad. Doing a diagnostics should not drop the load.
Jan 17, 2014 | APC Symmetra PX SY64K160H UPS System
I now live outside the US and brought my compaq ups r3000 xr with me and am having a problem getting a receptacle to plug it into. my electrician needs a part number as he has never seen that type of...
First of all you should make sure that the UPS is capable of handling the mains voltage from the country you're into now. After that just cut the cable as close as possible to the old mains plug then add a new one - all you need to be sure is which is the ground wire and that is very easy to find out with a simple ohmmeter. When you will go back to the US all you will have to do is to replace the plug.
Sep 12, 2010 | Compaq UPS R3000 XR UPS System
APC passes its self test but no backup
More than likely it is the battery. These units simply test the voltage during the self test, and, although not typical, the battery voltage could be good without a load, but fail with a load. 3 years is generally the life span of SLA batteries. Replacement batteries are fairly inexpensive and can be found at: http://batteryinternational.com/ups-batteries-apc-batteries.html
May 25, 2010 | APC Back-UPS CS 500VA UPS System
Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
My UPS stopped to work. I pushed the reset button and I had no response. When it is plugged all the panel lights start to flash
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
Oct 18, 2009 | Tripp Lite Lite OmniSmart 1050 UPS System
Compaq UPS R3000 XR Comms cable
Hi Jon,
so we could use this link it as a solution for your problem?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=3447589&prodSeriesId=255222&lang=en&cc=us
Kind regards,
noris017
Feb 25, 2009 | Compaq UPS R3000 XR UPS System
HP R3000 XR (AF414A) UPS System Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
