Question about Kenmore Washing Machines
Can't find how to select spin only cycle on Kenmore 796.4027 washer control panel.
I am trying to winterize my Kenmore washer #796.4027. After adding RV antifreeze to washer drum according to manual (p. 21) I can't find how to select a SPIN only cycle from the control panel in order to drain the wash drum.
  • 1314 Answers
SOURCE: Spin/Drain cycle...Kenmore 417.40042990 Front load belt drive washer.
ok two companies make kenmore you have a frigidaire model i gave you instructions for whirlpool heres frigidaire I think your on the right track but a couple of things you need to know first that model washer wont spin tiny loads or one articles of clothing it has a device in the motor called a tacho generator to balance if you have only a small load it cant sense the balance and most of the time will only rock back and forth second your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take your finger and feel up in the large rubber hose for any thing in there the drain pump should turn pretty freely if nothing is restricting it
Posted on Jan 20, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
njvinod
  • 1462 Answers
SOURCE: Frididaire ftfb4000fs1. Washer. Will not spin
IT IS THE ISSUE WITH THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE,
THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. YOU CAN FIX IT YOURSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY,
YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE
Please leave me comment, if you need further assistance
Thanks for using Fixya
Please rate this solution
Rnj VinodKumar
Posted on Dec 15, 2009
Testimonial: "I would have never guessed that one. You were correct. Thanks. "
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series
sounds like the lid switch has failed-no clicking usually means it is broken.
If you can get the top control panel up,you will see the molex plug that connects the harness to the switch.Jump the white and gray wires out and see if the unit spins.
Good Luck!
Mar 22, 2009 | Kenmore 20722
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
