Question about Toro "Toro" Super Blower/Vac
Interlock switch how do i reinstall the interlock switch on a toro model 51587 electric blower
4 Suggested Answers
bbreton
  • 437 Answers
SOURCE: I need the Manual for this Electric Blower.
Go to toro.com. Put in your model number and i was able to find the manual at the Toro store.
Posted on Dec 30, 2009
  • 10 Answers
SOURCE: Where can I find brushes
True to an extent but not just any brushes, just be sure to find brushes with the same flex wiring connection and then shave away. You'll need to shave them into the original shape for the ends and length as well as the lateral dimensions, so the springs will fit right.
I had to do this for a Shop Vac, took a few weeks to locate some brushes that would work right with the springs and the wire connection once shaved.
The motor unit was all the OEM would sell, and for the price I could get a new unit. :) Don't you just love a disposable design ethic?
Posted on Jun 09, 2010
2strokeguy
  • 183 Answers
SOURCE: i need a toro impeller
The impeller for your Toro blower is part #98-3150 and is available from www.partstree.com for about $20 plus shipping. To avoid shipping charges, find your local Toro dealer. Go to www.toro.com to find your nearest dealer.
An exploded parts view is also provided on partstree.com's website. This should make it easier to see what has to come apart for the impeller to be replaced.
Posted on Nov 12, 2010
Motor won't turn on
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Bypass interlocking switch
It's a safety device, so it's probably not a good idea. You can remove the switch and connect the two wires.
Nov 17, 2013 | Toro Electric Ultra Blower/Vac 12 Amp
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
I need a toro impeller model no 51553 or 51587
Nov 12, 2010 | Toro "Toro" Super Blower/Vac
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
Will not start . This is an electric blower.
There is an interlock on the air inlet (where the leaf chute fits when in vacuum mode or a grille fits in blower mode.) If either of those items is not installed and locked in place (by rotating until it clicks) the power will not go on. If the above devices are correctly installed and the unit does not run there is a problem with the plug that the extension cord attaches to, the switch or the motor.
Dec 19, 2009 | Toro "Toro" Super Blower/Vac
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
We have a leaf blower 51587 and I don't know how to get the blower on instead of the mulcher. Thank you.
Go to the Toro site I listed below. Choose your model and it takes you to a very neat interactive manual. Basically, the blower tube goes where the bag goes. Just about the extent of it. Good Luck.
http://www.toro.com/home/customercare/interactivemanuals.html
Oct 25, 2009 | Garden
Engage on/off switch will not start
the diode is bad on the start switch check with a meter for amps
Apr 05, 2009 | Toro Blowers Rake and Vac - Electric...
Toro "Toro" Super Blower/Vac Logo
70 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
