Question about Plantronics Radio Communications
Dect 6.0 not charging
Wirless headset not charging
All of a sudden screen went blank charger is plugged in not charging.please help me
Most likely, your rechargeable battery went dead. Replace the battery, charge it fully overnight, and the phone should be fine again.
May 14, 2015 | Uniden DWX337 DECT 6.0 Waterproof...
Why does my handset no longer show my caller I.d. information? And the chargeight on my base stays on even when the hand set is removed, why?
Hi Debra,
There are several reasons that this could happen:
1. Your telephone company stopped the service, even though you are paying for it... Ask your telephone company to verify your Caller ID service is current.
2. There may be a problem with your Caller ID service. Ask your telephone company to check to see if there are any problems.
3. Sometimes the caller ID is delayed, try letting incoming calls ring at least twice before answering.
The "charge" light staying on is very unusual, It could mean that the battery is failing, but if it is working properly, don't worry about it.
Best regards,
Bill
Oct 25, 2014 | Uniden DECT1560 DECT 6.0 Expandable...
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
Our DECT 6.0 4 phone system has been working fine for well over 1 year. All of the sudden when you dial out and the person on the other end answers they can't hear you. If someone calls here you can hear...
Sit the headset units back to the main base one by one.
Make sure you do all of them at the sametime.
This will reset the DECT 6 security feature.
Swap out the rechargeable battery to rule out weak battery problem.
Oct 22, 2013 | AT&T DECT 6.0 Cordless Phone System with...
I have a wirless xbox 360 headset and it was working about 4 days ago and I had it on charge when it died when I went to charge it wouldn't charge or turn on and I have had it to long to take back to...
so you are saying that you have a chargeable microsoft headset and the last time you tired to charge it. it would not work... it sounds like your rechargeable battery is dead and you might need a new one. also try you head set on a friends unit and see if it works, at the same time take their chargeable battery and place it in your headset and see if it works that will tell you if it is your headset or the battery..
game tag DeepReserve
May 19, 2011 | Microsoft Wireless Headset for Xbox 360
I charges my wirless mic and when i turn it on it
pair the headset to the xbox by pushing the small button on the xbox and the small button on your headset once it pairs make sure the number on the headset on the headset is the same as the number on the controller otherwise you wont be able to hear or talk to people online
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR SOLUTION TANKS.
Jun 11, 2009 | Microsoft Wireless Headset for Xbox 360
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Call transfer problem between Philips VOIP8411B and Plantronics C65 headset
sounds simple in the manufacture hand book that came with head set
states on some models they have this particular compatible mode built in
depending on specs of phone and headset gotta make sure that they were built with these built in specs and not all dect/gap work with other sets
Jun 02, 2008 | Philips VOIP8411B/37 IP Phone
Radio Communications Logo
22 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
