Question about Bowflex TreadClimber TC5
The console doesn't display the time, calorie, distance and speed mode.
    Top Expert:
  • Bowflex Master
  • 12,223 Answers
Adjust the REED switch, see the diagram attached, clean it, and test for open or faulty, tight the connector very well.
2) tight the ribbon cable inside, and clean it.
3) tight the upper connector and lower connector and clean it.
4) measure the input voltage to the board display.
5) if your system has batteries replace by new ones with the same type alkalines (clean the contacts batteries very well from oxide, corrosion)
God bless you
the console doesn't display the time, calorie, dis - e383cbf0-d33b-4a50-a79c-4c016cb33613.gifc85f8073-37a3-43bb-bb65-b269a2b08099.jpg
Posted on Nov 27, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a TC5 and the console is not working correctly
Dear Sir:
Please 1) adjust the reed switch attached is diagram
1a)Tight the flexible cable from keypad + tight the connector from display board vs lower board.
2) Run the software calibration for easy diagnose and troubleshooting.
If you can Not run your s. calibration see my personal TIPS, for diagnose and troubleshooting.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 29, 2012
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
York 2750 treadmill: How do I reset distance display? regards
Does anyone know where I can buy a replacement earlip pulse monitor for York 2750 treadmill?
Jun 27, 2011 | Health & Beauty
Nordictrack exp 1000 xl not shutting off
Your treadmill is in "Demonstration mode".
Here are the instructions to shut it off.
First you must enter "Information mode".
To select the information mode, hold down the Stop
button whilst inserting the key into the console. When
the information mode is selected, the following information
will be shown:
Total number ofhours that the treadmill has been used.
The Distance/Incline display will show the total number of miles.
An "E," for English miles, or an "M," for metric kilometres.
If a "d" appears in the display, the console is in the "demo" mode.
Press the Speed - button so the Heart Rate/Calories display is blank.
To exit the information mode, remove the key from the console.
Please be advised, when the safety key is removed THE TREADMILL IS NOT SHUT OFF, only the console is shut off. You must turn the machine off using the power switch in the front of the machine near the power cord, or I recommend purchasing a power bar with a power switch and turning the power off at the power bar.
Mar 01, 2011 | Nordic Track Exercise & Fitness
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
The meter that you set that tells you your speed, distance and calories burned stays at 0:0...the mode moves around when you push that but it stays registered at 0 for all modes. I put new batteries in it...
hi,
check ur tread mill's control consoles press button switches first. if all good the other chance is, ur control console have a programmed ic (integated circuit) in it. some programs are loaded in that ic, with which its displays speed distance traveled and all other settings. may be posibiliy for the ic get faulty. if so, the any way is consult the manufacturer, because you will not get the same in open market.
ok
Dec 27, 2010 | Treadmill Doctor Weslo Cadence Ex16...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    I need to know how to change from time to speed.
    most likely there is a scroll or a function button on the console. By pressing that you can choose between the different functions of the display.  If yo dont have such button, look for something similar that will switch the data on the display.
    Mar 15, 2009 | Evolve Exercise & Fitness
    Bowflex TreadClimber TC5 Logo
    97 people viewed this question
    Top Bowflex Exercise & Fitness Experts
    Electro Med Services...
    Shehu Pro
    Shehu Pro
    Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
