Question about Car Audio & Video
Would like to rewire Astak 918T Camera due to missing and cut connectors
A friend gave me a Astak CM-918T surveillance camera and a wireless receiver with no hardware at all. Just camera and receiver that's it. The camera does not say wireless anywhere on it but it does have a mini ant connector on the back. There 4 wires hanging out the back of the camera which are Black, Red, White and Yellow. The camera is 12v. So I was wondering if I connected the red + black wires to a 12v power pack and the yellow and white wires to a RCA video cable will that make the camera operational? I'm not sure if this will help but the receiver is a Astak CM-919 DC8V 0.9 GHz.
simplemitch
  • 752 Answers
SOURCE: CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Posted on Nov 09, 2007
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
the logos1
  • 8 Answers
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
Posted on Apr 01, 2009
  • 27 Answers
SOURCE: hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Posted on Apr 22, 2009
Manuals for astak cm-818T wireless camers
go to they site:
https://www.astak.com/support.php
fill in request and have good luck with it... it was despicable camera and system and i do not about the site...
some video on the subject - and comments...:
https://www.youtube.com/watch?v=1r_3EAXT_pM
hope this will help you - do not forget to vote...
Mar 21, 2015 | Home Security
Manual for a ASTAK CM 818t night vision
Your request sent directly to Astak could yield the manual.
Jun 30, 2014 | Lorex Weatherproof Color Day/Night Camera...
Would like to rewire Astak CM-918 camera due to missing hardware
Red and black, are power; white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Nov 26, 2013 | Astak Home Security
Manual for astak night vision cmos camera 2.4 ghz wireless receiver
The Astak Night Vision Wireless CMOS Camera is also known as a CM-818T. It is a wireless camera, that you HAVE to have the Astak Receiver, I believe 919. The camera is part of a security set that has 4 to 8 cameras and a specific receiver that receives the camera signal and saves it to a proprietary DVR. Frankly, what you have at this point without spending about $300 is a rock. If you want a cheap camera, try looking at Harbor Freight. Not that it is better or worse, but at least for under a 100 you can get a camera and a monitor that work. Only down side is that you have to hardwire it. Then again, wireless has a tendency to bleed signal. Lots of people with after market backup cameras can view your camera signal and you wouldn't even know about it. By the way, all of the sites that have a "manual" for this camera all have Non-Malware detected on them. Do yourself a favor and go buy something from a reputable person or company. Isn't your security worth paying something for? That is kind of like buying the most expensive stuff you can for a motorcycle and putting on a helmet you got from Goodwill. Just my humble opinion. Good luck.
UPDATE: I have found several of the 909 receivers on ebay for about 20 to 50 bucks, depending on which ones you select These might be useful if you were to want to try it. Good luck.
Oct 18, 2013 | Home Security
Need av cable for astak 2.4ghz wireless receiver
I need astak wireless reciver av cord where can i fine one at please
Apr 11, 2013 | Astak 24GHz Night Vision Indoor Outdoor...
Set up instructions for ASTAK CM-909 wireless receiver
https://files.acrobat.com/a/preview/50207bee-6d42-4187-9978-a56e55f79a3b
click this link if it doesnt work email me at tabish6877@gmail.com AND i will send it to your email
Sep 24, 2012 | Astak Wireless 2.4ghz Night Vision Color...
Need users manual for ASTAK CM-909 wireless receiver
User Manual :-https://files.acrobat.com/a/preview/50207bee-6d42-4187-9978-a56e55f79a3b
Email: support@astak.com
Call: 1-866-368-8788
Business Hour:
Mon - Fri 9AM-6PM Pacific Standard Time (PST)
Sep 24, 2012 | Vision Astak CM-840J 2.4GHz Wireless...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
