Question about Refrigerators
Replace fridge door gasket - Refrigerators
  • john molloy Nov 29, 2013
    call a repairman
    Scholar:
    New Friend:
  • 81 Answers
Those just pull off, unless you're on a subzero. Then they're all bolted on. But it should just pull off, then you start on the top and slowly start pressing the seal into the grooves.
Posted on Nov 28, 2013
Testimonial: "That's not even close"
    does not solve problem
  • Steve Burt Feb 01, 2015
    Well the information you provided was insignificant. Perhaps if you say something other than "Car door dont work help" Someone may be able to be more specific.
Help to restore 1954 GE fridge door gasket. The gasket brackets are missing.
Hello Karen
Try somewhere like this
Refrigerator Parts
Gaskets for Antique or Vintage Refrigerators - YouTube
? 4:55
https://www.youtube.com/watch?v=39IRu2ATUA0
Jan 27, 2011 - Uploaded by AntiqueAppliances
... on two doors, no locks on the doors and not have the back cover. Do you have any pictures of this this ...
IMAGES
1954 GE fridge door gasket Google Search
Dec 01, 2017 | GE Refrigerators
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
The door liner is cracked and broken the the fridge works great i would like to replace it where do i get a new one
Door rubber gasket is available with any fridge dealer retail shop. And also easy to replace.Below the gasket there are screws. Unscrew and fix new rubber gasket after removing existing one. If you can't call repairman. Matter of 2 to 3 hrs job. Thanks.
Jan 23, 2011 | Refrigerators
When I shut the left door the right door pops open, it is always open.... I need it to stay shut
put some heavy stuff on the door like soda or water bottles,also wash around the frame where the door gasket touches the fridge and wash the gasket too, there are magnets inside the gasket and if there's anything on the frame it could stop the gasket from making a good seal,how old is the fridge?what shape is the gasket in?if it's torn or lost it's shape it should be replaced.most likely you might just have to get some weight on the door to stop it from popping open
Mar 07, 2010 | Maytag MFD2561HE Bottom Freezer French...
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Door gasket failure
DIY absolutely. Easy job with replacement part just re-thread the strip into the grove to replace.
Apr 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Side side door noise(fridge side door)
you need the lower hinge and cam kit. remeve the top hinge then lift the door off the hinge and replace the hinge and the cam on the door.
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator Door Gasket Has Split
I FIND IT VERY STRANGE THAT THE ENTIRE DOOR NEEDS TO BE REPLACED IN THE EVENT THAT THE RUBBER IS FAULTY.I NO FOR A FACT THAT SOME SAMSUNG FRIDGE RUBBERS ARE QUITE HARD TO REPLACE AND THE QUICKEST SOLUTION FOR THE TECH IS TO REPLACE THE ENTIRE DOOR.TO ESTABLISH IF THE RUBBER IS REPLACABLE I SUGGEST YOU LIFT THE GASKET IN ONE CORNER AND LOOK FOR A GROOVE OR SCREWS.SOME RUBBERS ARE BASED ON A PUSH IN PULL OUT BASIS.IF YOU FIND IT HARD TO ESTABLISH WHICH IT IS I THINK ITS BEST YOU ASK SAMSUNG TO SEND YOU A MORE ADVANCED TECH TO ASSIST YOU IN THAT REGARD.ALSO YOU CAN VISIT SAMSUNG WEBSITE AND FIND A TECH NEAR YOU.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
