Question about Whirlpool Refrigerators
Frigidaire com The icemaker in our FRS6R4EW is not working wel,sometimes it works and then it won't turn the cubes in to the basket en it won't fill with water
    Genius:
  • 1,198 Answers
The ice maker timer is replaceable. Only a couple of screws hold the ice maker in the freezer, take it out and see if you can remove the timer for replacement. If you like to tinker, take it apart to see the pitiful connections, maybe you can fix it.
Posted on Nov 27, 2013
catriver
  • 878 Answers
SOURCE: Ice Maker
Charles, these models have a habit of the inlet tube freezing over. Make sure the black tube feeding the trough is clear. You may want to disconnect it from the back and see if you can blow through it. I use hot water in a baster to clear them all the time. Another thing is to check the optics. When opening the freezer door the red optic light on the right should flash 2x with a pause repeatedly. When you close the left hand emitter flapper the light should stay on. If it does this your optics are good. Because of these optics the new ice-maker has to be jumped started into a cycle. Once started you can monitor the fill. Catriver..post back.
Posted on Aug 09, 2006
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
SOURCE: icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Posted on Jul 01, 2008
SOURCE: KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Posted on Dec 05, 2008
Ice maker leaking water
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
Freezer is not making ice, help?
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire Gallery Model GS26HSZBB2 ice maker doesn't fill up
Hello.
It is time to replace your icemaker. The best place I have found to get them is at Lowes. They are above 100 dollars everywhere else but they are 49.99 at Lowes. The part number is IM115. Just let the guy in appliances know you need an icemaker for a Frigidaire unit.
Jul 22, 2009 | Refrigerators
Icemakers,frigidare, gallery series
read the menual book and try again or replace it.
Jul 18, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire ice maker not filling
I am not familiar with the model, but if it has water and power and will dump cubes, then I suspect the problem is in whatever gizmo Frigidaire uses to keep the cube bin from overfilling with frozen cubes. Something is keeping the fill valve from opening. Not much advice, I know, but I hope it helps.
Oct 23, 2017 | Frigidaire FRS6R5EMB Side by Side...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice trays overfill leaking into the basket
FIND ADJUSTMENT SCREW UNDER ICEMAKER COVER AND TURN DOWN ICE CUBE SIZE,REPLACE AUGER,THANKS-MIKE
Jan 13, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
