Question about Archos 80 G9 Tablet
Archos g9 reboots after 10 seconds
Reboots on its own has a 10 second count down
Samsung trouble shooting
Almost certainly you have a broken screen. Replacement screens run about $140 and are not very difficult to replace yourself. A website that provides these screens and a "how to" video on their replacement can be found at: http://www.laptopscreen.com/English/model/Archos/101%20G9%20TABLET%20TURBO/
Be sure that you are requesting an exact replacement before ordering. I am not affiliated with this website, and am sure there are other sources.
You may wish to search eBay for a used "for parts only" replacement at a fraction of the cost such as this one which last bid was a little over $10: http://www.ebay.com/itm/Archos-101-G9-TURBO-10-1-8-GB-Tablet-no-power-/111364604971?pt=US_Tablets&hash=item19edd9042b
Alternatively, you can buy a nice used one for about $100 at: http://www.ebay.com/itm/Archos-10-1-Android-Internet-Tablet-101-16GB-Wi-Fi-IN-BOX-with-access-501594-/251536519730?pt=US_Tablets&hash=item3a90beb232
I personally would go with the last choice and keep yours for spare parts. Good luck!
May 28, 2014 | Archos 101 Internet Tablet 16GB 10.1"...
How do i factory reset my kindle wich is locked internaly
Hold the power button in for 20 seconds (count the seconds) and ignore any message you see about shutting down the kindle. after 20 seconds, release the power button and press it again. the kindle should reboot. Then go to menu, settings, restore
Nov 15, 2013 | Tablets & eReaders
Hi, my Archos 80 g9 display screen is broken, can i buy new display from you?
the display screens can be purchased but good luck finding some one to install it just google it and buy 2 because often some of them dont work from the factory ooorrr you can have archos fix it wich may be cheaper and easyer about 25% of original cost and they will test it and make sure it works before sending it back or send you a new one the screen problem is not specific to archos its specific to that type of screen they have a half life of about 5 years but may die sooner under constant use or abuse and some die as soon as they are powered having archos replace it prevents you from having to buy multiple of them to find a good one samsung also uses the same type of screen but does not use the laminating or layering proces that archos uses to increase the durability and third party screens also dont have this eather so having archos do it will also ensure you get a laminated and layered set up that will last you a bit longer than one you might purchase after market and have some one put in for you
Jul 10, 2012 | Archos 80 G9 Tablet
My tablet as frozen i am unable toswitch it off
Hold down your power button for 15 seconds.
Feb 05, 2012 | Archos Tablets & eReaders
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Oct 16, 2011 | Archos ARNOVA 10 Android Tablet
Wont turn off or respond is there a reset somewhere ?
Hi there. A reset is done on this tablet by holding the power button for at least 10 seconds. hopefully this will reboot it and it will start responding again.
Sep 10, 2011 | Archos 101 Tablet PC
My archos froze and i cant unfreeze it
I am glad to HELP YOU!
To UNFREEZE your device you have to do like this:
# press and hold DOWN your POWER button for 10 seconds
# once the device is POWERED OFF recharge the battery COMPLETELY
# when battery is FULL restart your Archos 101.
And make sure your firmware is UPDATED!
Now your device should work properly!
GOOD LUCK!
... and don't forget to RATE, please...
useful WINDOWS TIPS!
May 01, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
Feb 20, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 80 G9 Tablet Logo
18 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
