Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
I lost my cd driver of my motherboard p4m266 8233 and my secondary ide port is not actif
    President:
  • 1,383 Answers
Http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1704&lang=eng
select your operating system and downlaod all drivers.
Posted on May 08, 2009
Lost my installation and information cd for 3-in-1 mad dog 52x cd-rw
I can't tell you where it is sorry, but if you are running an operating system ie windows xp or newer you will not need any drivers, also depending on what ports your motherboard has you only need to connect his to either an ide port(old type) remembering that you may have a hard drive connected into one of them also you will need to set the pins to iether primary or secondary again this depends on what setup you have on your motherboard. we really need more info
You can always try surfing the new via say google or look through a webste called tops hardware for your drive.
Jun 30, 2010 | Mad Dog Multimedia (md-52xcdr) CD-RW...
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Oct 12, 2009 | Intel D865GVHZ Motherboard
Raid settings, i one to set sata drive as primary and ide as secondery
First connect the SATA to port 0 Sata does not have any Primary or secondary port, It has ports SATA0,SATA1,SATA 2, 3 and 4(depending upon the number of ports available on your motherboard), Connect the SATA to port SATA0
Then connect another Drive to IDE 2(secondary). Normally the IDE port closer to the RAM is primary.
To confirm the connection is correct you can look in the BIOS
Please let me know if this information is helpful to you. If you find it helpful please do not forget to rate it.
Thank you for choosing Fixya
Oct 08, 2009 | Intel Motherboard
Ide not work
there may be some problem in the ide cable just change the ide cable and try once .. you can check it by going to BIOS whether after replacing the ide cable the device detects or not ..
if you persist same problem then there may be some problem in the secondary IDE port(may be some pin might have broken or some short circuit might have occured have a check) just take your motherboard to the motherboard technician if so ...
Sep 08, 2008 | ASUS P5S800-VM Motherboard
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
Ide 3 and 4 ports
good pm...
ide 1 - primary master (your hard disk)
ide 2 - primary slave (your cdrom)
ide 3 - secondary master
ide 4 - secondary slave
hope this will help...
Mar 07, 2008 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
263 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
