Emerson 2gb will not connect to computer
    New Friend:
  • 3 Answers
YES
Posted on Nov 26, 2013
I HAVE THE EMERSON 2GB EMP385-2 AND WHEN I CONNECT IT TO THE COMPUTER IT KEEPS WANTING TO FORMAT IT. BUT IT WILL LOSE THE MUSIC. WHAT DO I DO TO DOWNLOAD THE MUSIC ONTO MY COMPUTER
Okay, first of all: i dont think there is anything you can do to get your music back in original quality.
but there are some tools that might help you:
Undelete Plus is one. It can recover files from currupted usbs, but again, you will most likely lose some of the bits in your music.
there are also some ways of making the device uncorrupt again
try this guide.
but it would have been easier to make a backup of your music :)
Mar 14, 2011 | Audio Players & Recorders
Can i hook up my 32 in emerson to my computer for netflix
Yes you can . Do the instructions below and then just download the Netflix movie like you would if you where to watch it on your PC. After all connections you should be able to watch it on your Tv screen, Enjoy.
Things You'll Need:
VGA to VGA cable
DVI to VGA adapter (as needed)
How to Connect a Computer to an Emerson TV
Purchase a VGA cable and a DVI to VGA converter (if needed). The VGA cable is a cable with blue attachments on either end that contains a total of 15 pins (arranged in a 5x3 lineup). You will only need the VGA to DVI adapter if your computer does not have a blue VGA connector on the back.
Attach the VGA cable to the VGA port on the back of your computer (going through the DVI to VGA adapter if necessary). When screwing the connector in, alternate between the two sides periodically. Tighten one side of the connector a little, then tighten the other side of the connector to match. This will ensure a tight connection and an optimal picture.
Attach the VGA cable to the back of your Emerson television, utilizing the same alternating tightening method that you used to secure the cable to your computer.
Use the menu button on the Emerson TV to select a new "source." Choose "VGA" input, then confirm that by pressing the OK button (normally the volume+ button on most televisions). The television should immediately switch to display the computer's output. If it takes you to a blue screen instead, simply restart the computer in order to reset the connection.
Feb 12, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I lost my Emerson EMP516-2 2GB software
go to their website and support then mp3 and search for software for your model
Aug 30, 2010 | Emerson Audio Players & Recorders
How can i add video to my emerson mp3 player
The Key-point of adding videos to emersonMP3 player is that ensure the vids are in right format .3GP. Daniusoft video converter is pretty good at this work, and it even can extract background music off videos to MP3 players for free ...
Free trial link: http://convert-video-dvd.com/video-converter.html
Guide: How to extract mp3 music from YouTune videos...
Feb 12, 2010 | Audio Players & Recorders
I can't put videos on my emerson 516-2 2gb player
Please make sure your video files to your memory is not up to the player's memory.
Jan 20, 2010 | Emerson MP530 MP3 Player
How do you delete mustic frm Emerson 516-2 (2gb)
Connect to computer, open folder, delete music. Then unplug and go to music, second to last function updates music library (update musiclib). Click on that and it will show your current music in the folder (or show it empty if you deleted it all out).
Dec 10, 2009 | Emerson Audio Players & Recorders
The driver for my Emerson 2gb MP3 player is on an undersized cd. How do I get the driver?
Emerson does not have a support page on their web-site for driver downloads.
Dont know if this will work, try it:
Update driver on your computer using Control Panel, then System, then Hardware, then Device Manager, then Storage Volumes. When promted to update or find a new driver select to find your own windows driver and select the "USB Storage Device" drivers NOT the MTP Drivers. You should see the Emerson MP3 player icon in My Computer after files are configured.
You can also see if some friends might have a CD/DVD player that accepts the smaller discs, if so, have them copy the entire disc to a USB Flash drive or regular CD. Then try to install it from there.
Dec 01, 2009 | Emerson MP530 MP3 Player
Recharging batt. on emerson mp3 digital media player
if your mp3 player comes with a usb charge cord and has no bulge in the cord, such as would contain some kind of voltage modification electronics, then it's ok.
   the reason is: both the motorola charger and the usb port are  5 volts, all usb is 5 volts standard, and the motorola charger is labeled 5 volts right on the unit itself.
    The the only possible problem would be if the motorola charger was wired differently. However I have been using my razor charger to charge my Emerson 2GB mp3 player w/no problem.
    Plug in the charger with the mp3 player powered up, you should see the battery icon filling up just as if you were using the usb charger.
    if you are still to worried to try it , then get a voltage meter and test the polarity (weather positive and negative are the same on the motorola charger as the usb cord when plugged into the computer.
Sep 04, 2008 | Audio Players & Recorders
13 people viewed this question
 Grubhead
Grubhead
