Question about Boating
Johnson oceanrunner 175
Starts ok cold and runs great. after shutting off for a while and starting when motor is somewhat warm won't idle/ stalls for about 5 min.
    Genius:
  • 1,198 Answers
Outboards are finicky about fuel, probably don't like ethanol. Try some high test.
Posted on Nov 27, 2013
2 Suggested Answers
finish line
  • 207 Answers
SOURCE: stater problems
do u need this for a charging issue or a firing issue?
Posted on Jun 27, 2009
93 S10 4.3 starts great when cold but warm idle gets rough almost to point of stall and won't restart when shut off
run the fault codes if EFI engine
check the automatic choke setting for a carby
Sep 06, 2015 | Cars & Trucks
98 Mustang stalling after start
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Jan 16, 2014 | 1998 Nissan Maxima
Engine seems to stall when first starting in cold weather after its warm it runns great
Will it stay running if you keep your foot on the gas? If yes it sounds like you might have a bad Idle air control motor.
Mar 30, 2010 | 2001 Ford Windstar
My 175 hp 1998 johnson (carbeurated model) is hard to start. When started it seems to run ok, but after motoring for 10 or so minutes, will just die.
Sounds to me that your carb is plugged up. I would take it apart and clean it. Also make sure your idle mixture screw is set to 1 1/2 turns out to start and adjust from there.
Aug 13, 2009 | Boating
Johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
8hp johnson, 1999,plugs good, wires good,have put in new gasoline 50.1 mix, runs great at higher rpms. When cold start, it will idle at slow rpm. Once warmed up or a hot day, it will not idle when the...
have u tried to adjust you timming linkage? its on the side of the motor where the shifter linkage is try to turn the bolt in or out while running you may get it to idle better if the power pack was bad the engine would cut out at all speeds
Apr 16, 2009 | Light Outboard Motor Boat Bass Fishing...
4 cyl Engine starts and idles ok...give it throttle and it dies
I need to get a clear mental picture of what exactly is happening.
With this said, you stated that the car "runs fine" until warmed up.
Q: When you start the car when cold it idles fine?
Q: If you allow the car to idle until "fully" warmed does the car stall?
Q: As the car begins to warm up, Does the RPM fluctuate abnormally?
Q: Does the car Only stall when you press on the gas pedal or does it stall just sitting and idling in addition to pressing the gas pedal?
Q: If you can drive it while cold does the car stall during acceleration when warm or only at Stop Signs / Lights?
Q: If you wait 20min or so, can you start the car again?
Q: How many miles are on the car?
Mar 27, 2009 | 1995 Toyota Camry
Motor shuts off as soon as I start to accelerate.
Might be a fault in the side stand sensor, you cant go far with the side stand out, or if the sensor has not sensed the stand is up.
Mar 15, 2009 | 1996 kawasaki VN 800 Vulcan Classic
Car not idling adn stalling when it is cold
sounds like the idle control vale is sticking when it is cold. It is located on the throttlebody right at the air inlet
Feb 24, 2009 | 2001 Mercury Sable
93'Saturn engine problem:
engine coolant temp sensor is most likely cracked.. I know it sounds strange but pull it if your looking at the engine it is on the right side of the head Will make the car hard to start, smoke, and the idle will often race up and down.. easy to fix 15 dollars or so..
Jan 07, 2009 | 1993 Saturn SC2
Boating Logo
69 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
