Question about Metra Car Audio & Video
Hyundai hsh3001ba My condenser fan blade has shattered. Could you point me in the right direction to buy a replacement please? Terry
RepairUSA
  • 50 Answers
SOURCE: Condenser fan mounting
Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
Posted on Aug 10, 2007
  • 112 Answers
SOURCE: auto directional light lens is shattered
Forget the lens repair---it won't happen. You need to replace the whole assembly.
Purchase a used one at a salvage yard, and avoid the dealer. No one wants to sell a lens cover--trust me.
And, if you do happen to find (an aftermarket made in China), it won't meet Federal Standards, and could keep you from getting a valid vehicle inspection sticker (should you be in a state where you need it).
Posted on Mar 26, 2009
crouchdash
  • 83 Answers
SOURCE: I need to replace my condenser fan motor.
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
Posted on May 08, 2009
james3751
  • 614 Answers
SOURCE: Condenser fan rotating the wrong way
If nothing has been changed you have a bad capacitor and need to change it. Then the fan will run in the right direction. RUSS
Posted on Jul 18, 2009
SOURCE: I have a Hunter ceiling
Here is the link to the Hunter Fan web site for the manuals for model 21350.
http://www.hunterfan.com/Search.aspx?search=21350
Posted on May 30, 2011
I need the blue neon light kit for the Hampton Bay fan chrome finish with clear blades
Fixya does not sell blue neon light kits for Hampton Bay fans.
Mar 03, 2018 | Hampton Bay Dryers
I have a broken ceiling fan blade arm for Harbor Breeze Model #OM52-5B/Q1M (outdoor fan). Can I get a replacement arm or do I have to buy a whole new fan?
you will have to get 3 (4) blades as they have to be exactly the same
At this point I would advise a new fan because the settings of the blades have to be exact or it will wobble all over the place
to explain even with a new unit, the fan blades have to be measured from a fixed surface ( normally the ceiling
each tip of the blade has to be the same distance and the front and back of the blade measurements at the tip have to be the same on all blades
If you get it right the fan will spin without any movement
Mar 02, 2016 | Dryers
I have a Vizio e601i-a3 TV , an angry gamer threw the control and brother the screen. it till turns on ut it looks like shattered glass around the impact spot. I have been searching high and low on google...
The cost of the screen, and the tools needed to make it work with your current TV would be more expensive than it would be buying another TV. Go find the gamer that caused the damage and get them to buy you a new TV.
Oct 03, 2013 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I just replaced the motor to the condenser fan, after I put the blade back on, and finally got everything moved and screwed back down I am wondering if I put the blade on so the air flow is going in t
If you replaced the fan motor with the correct rotation replacement motor the fan should be blowing in the right direction or did I misunderstand what you are trying to explain? Sea Breeze If the part number is=> WR60X187 the motor should be turning clockwise rotation while looking at the motor from the rear. Thanks JT
Jan 26, 2013 | GE Monogram Side by Side Refrigerator
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
A/C tech tells me the replacement motor I am using is pull 2.3 amps and the unit wants 2.5 and so the motor shuts off. But the plate on the back of the condenser says it should be 1.6 amps. I would like to...
The fan blade size, pitch, rpm, number of blades and diameter, determine the motor size and rpm.
If your condenser says it should be 1.6 amps and you have 2.3 amp motor in the unit, you have a stronger motor than you need and the motor should not be getting hot and shutting off.
You need to make sure somebody didn't change the blade or the rpm of the motor or the rotation or direction the motor turns. If those are correct then you need to make sure you have the right size capacitor, The size (microfarads and volts) is usually on the motor nameplate. If it's the right one then you need to have it checked and make sure it's good.
Jun 10, 2010 | Heating & Cooling
Jul 17, 2009 | Heating & Cooling
How do I reverse the direction that my condenser fan is blowing?
You would have to replace the fan blade with one with the opposite pitch. In other words a fan that is a mirror image of the one in place. You cannot reverse the flow by flipping the fan blades over.
Why do you want to reverse the direction? I can think of no benefit in doing so. But then again you posted this under a Water Filtration heading?
Jul 17, 2009 | General Electric GE SmartWater Household...
Aug 08, 2007 | Ruud UAKA030 Air Conditioner
Car Audio & Video Logo
14 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
